- Thank you received: 3
carb rebuild
- stonemaster
- Visitor
thanx
- cobura
- forever 2 wheels
1979 KZ650B3
- Thank you received: 2237
- Thank you received: 2098
I'm rebuilding carbs on my 73 Z1, mikuni 28's question, what is proper procedure to remove needle jet?? FSM doesnt say anything just "disassemble carb" well duh and the the haynes gives some clue, Remove control arm and ???? anybody have a more comprehensive set of directions to accomplish this task, the rest of it is pretty simple i just want to be sure of my steps
thanx
Forgive wanting to confirm needle jet is to be removed, and not the jet needle, or some other part such as the air bleed pipe, etc.
Reason for asking is that needle jet is, I believe, pressed into the carb body (removable by using a wooden dowel as a drift tool) and not so frequently removed and replaced. Although, replacement of needle jet may be indicated where it's wallowed out after extended use from interaction of the jet needle moving up and down inside it.
- stonemaster
- Visitor
- stonemaster
- Visitor
thanx guys
- stonemaster
- Visitor
- HT8R
- Visitor
- stonemaster
- Visitor
