crash / tank came off / 100ft flame trail
- Beard
Ok not really, BUT
i checked with a buddy both of our kz650's have 3 fuel tank mounting points.. the 2 rubber pucks up front and the rear mounting hole near the seat that the post from the tank goes through.
what is really holding this tank on? i know its worked since the 70's but am i crazy to have the want to drill a hole through the post on the bottom of the tank.. then slip it thorugh the rear frame mounting hole and then put a clevis pin through the newly drilled hole?
79 KZ650B
Jack of everything, Master of nothing.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Beard
79 KZ650B
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kz750saskatoon
- Thank you received: 2
My KZ750 H2 has the two pucks up front and at the back a grommet that a bolt actually goes through and screws to the frame.
I like my bike's solution better.
1981 KZ750-H2
Saskatoon, SK
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Thank you received: 2829
Actually, the stock seat is locked down and rests against the rear of the tank. Try to pull the tank off with the seat locked down and see if you can pull it free. Maybe if the wreck was bad ebough the tank would come off, but if the wreck is that bad the tank might rupture anyway - in which case I would want it to fly as far from the bike and me as possible. Ed
- JMKZHI
- Thank you received: 48
Beard wrote:Mine snaps in tight. My 900 has what equates to a big rubberband on it...
What Kawickrice means is that his bike has a large rubberband or strap that holds the rear of the tank in place. He probably has the big grommet too. The diagrams at Kawasaki.com for you bike may show that your bike should have a strap.yes theres that rubber grommet that it snaps into.. but i see a big difference between something being just "snapped" into place or being physically restrained in place.
The rear of the tank on some (most?) 80s models are bolted to the frame.
- loudhvx
- Thank you received: 1616
I've been in two major crashes and the tanks stayed in place, but were banged up pretty good.
This is an ebay photo. You can see the tab extending off the back of the tank. Under the tank, near the back is a blade-shaped tab that points down and gets pressed into a slot-shaped grommet in the frame.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- TeK9iNe
- What did you do!?!
I thought the fuel line holds the tank on the bike :laugh:
If you want to get a tighter/less movement fit, try putting some pipe wrap sponge around the center tube, then scrunch the tank down on that. It holds it right in place nicely.
PS. On the later models, they switched to a bolt at the back that clamps the tank down in place.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Mcdroid
- Gone Kwackers
- Thank you received: 319
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Kawickrice
My 650 has a spade that stabs the grommet. My 900 has a rubber band type. Totally different between the two bikes
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
