- Thank you received: 104
float needle
- stonemaster
- Visitor
18 Jul 2010 11:09 #383628
by stonemaster
float needle was created by stonemaster
I just opened up carbs and found something wierd, on 1 & 4 there is a wire attached to the float needle and hooked to the tang, on 2 & 3 the needle has a small spring loaded plunger and is not attached to the tang, WTF I dont see how this is working, given what the PO has done so far I'm not surprised, Experts ????
- PLUMMEN
18 Jul 2010 11:30 #383634
by PLUMMEN
Replied by PLUMMEN on topic float needle
float raises needle up/down,clip just holds it from falling out
- stonemaster
- Visitor
18 Jul 2010 12:16 #383642
by stonemaster
Replied by stonemaster on topic float needle
only two of the needle had them and the needles were different
- PLUMMEN
18 Jul 2010 13:15 #383646
by PLUMMEN
do they open/close with the float?
- stonemaster
- Visitor
18 Jul 2010 13:20 #383648
by stonemaster
one wasnt for sure because I wasa getting overflow, guess I'll jus rebuild em all and be done with it
thanx
thanx
