- Thank you received: 3
Stock jet sizes.
- Lazyman06
18 Jul 2010 06:38 #383562
by Lazyman06
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Stock jet sizes. was created by Lazyman06
pulled the bowls on the KZ yesterday the jets are main jets: not sure if said 120 or 720 but i'm going with 120, pilot was 22.5. I figure these are what came on it but wanna make sure because the pipes I got are completely open and it's running air pods so I figure it'll need to go up a few sizes.
- otakar
18 Jul 2010 07:18 #383569
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Stock jet sizes.
Stock jets for that bike are 102.5 main and 15 pilot. This means that the Idle is WAY too rich and so are your mains. The idle jets should be at most only one size larger than stock and in most situations the same as stock and the mains only about four sizes larger at best. Meaning about 112. Increase to 115 would be pushing it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
18 Jul 2010 08:22 #383590
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Stock jet sizes.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
18 Jul 2010 08:22 #383592
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Lazyman06
18 Jul 2010 10:44 #383619
by Lazyman06
Replied by Lazyman06 on topic Stock jet sizes.
Honestly I couldn't imagine the PO rejetting the carbs the stuff he's done to it didn't make him seem like the brightest bulb in the drawer. now on one picture it shows what otakar was saying but the second was completely different.
- Old Man Rock
18 Jul 2010 10:52 #383623
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Second image set via Z1 Ent.. is for Z1 & KZ900 jetting and smooth bores...
Not sure which one of your KZ1000's your asking about...
Go with the first image set.... Same time, these are OEM and pending what has been done to your engine (compression & cams), head valve size/porting, carb/exhaust/filters, elevations, atmospheric conditions etc... may not be ideal for your jetting...
Good starting point though to work from....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Lazyman06
18 Jul 2010 11:16 #383629
by Lazyman06
though while it'll suck gas like nobodys business and foul plugs every two days it won't hurt for the time being?
- Old Man Rock
18 Jul 2010 11:19 #383630
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Maybe these will help you out....
Carbs:
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
Spark Plug Reading:
kzrider.com/index.php?option=com_docman&...d&gid=460&Itemid=108
Keep at it....
OMR
Carbs:
Spark Plug Reading:
Keep at it....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Lazyman06
18 Jul 2010 11:29 #383633
by Lazyman06
thanks OMR. i'll check these out right away
- otakar
18 Jul 2010 11:35 #383635
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The jetting I listed was right out of the 1979 A3A Z1 MKII manual.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Lazyman06
18 Jul 2010 13:36 #383655
by Lazyman06
K then that's what i'll start with. Although the Jet guide calculator pretty much sums up what I need to do. I think i'll go ahead and get 4x 110 main and 4x 17 pilot jets
