- Thank you received: 540
sticking exhaust valve
- stonemaster
- Visitor
17 Jul 2010 20:03 #383494
by stonemaster
sticking exhaust valve was created by stonemaster
did valve clearances, still some ticking #4 exhaust valve, cured same once on my Dodge with Valve dDoctor. is similar remedy available on Planet 73 Z1 ???
- MFolks
17 Jul 2010 20:15 #383502
by MFolks
Replied by MFolks on topic sticking exhaust valve
This is supposed to work on stuck piston rings:
www.amazon.com/Yamaha-Ring-Additive-32oz...-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
And this is good for cleaning combustion chamber deposits:
Mopar Combustion Chamber Cleaner # 04318001.
Are you shure the valve is sticking? Checked by removing the sparkplugs,valve cover, and turning the engine over by using the 17mm "Nut" on the end of the crankcase?
If after turning by hand and the valve will not come up,I'd be suspicious of carbon build up/burned valve/burned valve seat.
- PLUMMEN
- Thank you received: 104
17 Jul 2010 20:21 #383504
by PLUMMEN
Replied by PLUMMEN on topic sticking exhaust valve
if the valve is physically stuck,youve got bigger problems! the cam and pistons tend to be unstoppable objects compared to a valve,the valve tends to lose that battle
- stonemaster
- Visitor
17 Jul 2010 20:54 #383515
by stonemaster
Replied by stonemaster on topic sticking exhaust valve
if you mean stuck by not moving no that isnt it, i mean a ticking/clicking sound as the valve apparently seats, on 4
34 exhaust
34 exhaust
- MFolks
17 Jul 2010 21:09 #383518
by MFolks
A little valve clatter is good on these engines, when they get quiet, then it's time to worry.
As the valves and seats wear, the clearances reduce, bringing the valve stem closer to the cams, requiring thinner shims when doing the periodic clearance checks.
Some of the Kawasaki's had shims sitting on a bucket type holder directly over the valve stem making checking/replacing a minor chore.
Other ones had the shim under the bucket requiring the cams removed(a major,time consuming job)re-installed and checked.
