Float Level Help Required
- pz1morton
16 Jul 2010 09:59 #383084
by pz1morton
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
Float Level Help Required was created by pz1morton
Hello all any help would be much appreciated.i have a set of mikuni bs34cv carbs that i use on my race bike.the problem i have is that i need to know the proper float level and the proper amount of fuel in the bowl too! as a measurement.someone must know some info or where one could go to get the right spec.thanks to all in advance.jet set up would be nice too.thanks again people.
Regards Paul Morton
VRRA # 757
RACE # 757
Regards Paul Morton
VRRA # 757
RACE # 757
1984 GPZ900
- TeK9iNe
- What did you do!?!
- Thank you received: 28
16 Jul 2010 10:07 #383085
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Float Level Help Required
Just attach a clear length of hose to the carb drain and hold it up to the carb bowl.
When you open the drain the fuel will fill the hose up to the fuel height in the bowl.
The proper fuel height for the BS34's is 2-3mm from the gasket surface. So basically right where the bottom of the lip overhanging the carb bowl.
Someone will pop in with diagrams for sure :laugh:
Jetting depends on the condition of the engine, the average outside temps/humidity, and your altitude, also intake pressure (air filter type), and exhaust. + some other factors... people can give you a ballpark number for jets, but it always comes down to guessing and testing.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kawickrice
- Thank you received: 18
16 Jul 2010 10:28 #383087
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Float Level Help Required
No eBay APP ID and/or Cert ID defined in Kunena configurationThis will make it a little easier for the clear tube method. Works like a charm
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
