vacuum leak around carb bases
- gcarson64
15 Jul 2010 20:53 #382981
by gcarson64
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
vacuum leak around carb bases was created by gcarson64
hello all, i have a problem. i took the carbs off to put a new cam chain tensioner, which was not a problem at all. but then when i put the carbs back on and started it. it ran fine ( WITH NO CAM CHAIN NOISE YAY!! ) but with the exception of the vacuum leak around the base of carbs 2 and 4. i did the starter fluid test to find out which one were the problem. well i took the carbs off again and put some silicon gasket maker on the carb bases ( all of the carbs not just 2 and 4 ). now i am waiting over night for it to dry and then i am goin to see if it fixed the problem. let me know if this is what you would have done. p.s. the bike rain great before, besides the cam chain noise.
- TerryK
- Thank you received: 3
15 Jul 2010 21:00 #382983
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic vacuum leak around carb bases
You put silicone on the sealing surface or around the flange itself? Either way it wont work. Gasoline will eat the silicone. If the flange is leaking the only solution is to replace them. Very common problem with 25 year old bikes!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- gcarson64
15 Jul 2010 21:57 #383000
by gcarson64
Replied by gcarson64 on topic vacuum leak around carb bases
where can i buy the flange parts. i also put the silicon on the sealing surface.
- MFolks
- Thank you received: 540
15 Jul 2010 22:25 #383004
by MFolks
Replied by MFolks on topic vacuum leak around carb bases
Contact
www.z1enterprises.com
for the carb holders(some riders call them manifolds).I believe z1 can get the rubber boots(ducting) from the air filter box to the carbs.
- gcarson64
15 Jul 2010 22:59 #383009
by gcarson64
thanks
