- Thank you received: 245
Z1-B Carb Overflow Hose Routing?
- Kidkawie
- I bleed premix
15 Jul 2010 08:02 #382826
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Z1-B Carb Overflow Hose Routing? was created by Kidkawie
I took the bike apart years ago and can't remember how the overflow lines are routed. Also, where does the rubber strap hook onto?
Thanks.
Thanks.
1975 Z1 900
2004 KX125
- blue75kz900
15 Jul 2010 08:13 #382828
by blue75kz900
Blue 1975 KZ900
Gold 1970 Chevy Nova 427...Bike killer
Replied by blue75kz900 on topic Z1-B Carb Overflow Hose Routing?
The hose should connect to the fitting at the bottom of the fuel bowl.
On my kz900 their about 18 inches long and just extend over the back of the motor between the swing arm and frame pointing down at the ground.
Blue 1975 KZ900
- Kidkawie
- I bleed premix
15 Jul 2010 08:24 #382830
by Kidkawie
1975 Z1 900
2004 KX125
Replied by Kidkawie on topic Z1-B Carb Overflow Hose Routing?
Thanks. What about that rubber band that secures the lines? Where does it mount on the chassis?
1975 Z1 900
2004 KX125
- blue75kz900
15 Jul 2010 12:32 #382857
by blue75kz900
Blue 1975 KZ900
Mine doesn't have any for the four lines. Mine just hang down.
You can just tie it too the frame if you want.
Blue 1975 KZ900
- MFolks
- Thank you received: 540
15 Jul 2010 15:14 #382891
by MFolks
Replied by MFolks on topic Z1-B Carb Overflow Hose Routing?
On some bikes the rubber grommet mounts next to an engine mounting bolt. I suppose a loose black ty-wrap or two could be used to keep the drain lines together.
Just don't over tighten the ty-wrap so it pinches the lines shut.
- Kidkawie
- I bleed premix
15 Jul 2010 16:24 #382903
by Kidkawie
1975 Z1 900
2004 KX125
I'm trying to get it back close to original. I have it looped around two harnesses under the battery box now. That's where it "felt" it wanted to be.
The actual part is: 92037-134 CLAMP,OVER FLOW PIPE
It's in the Frame/Fittings Section
1975 Z1 900
2004 KX125
- Thank you received: 2098
15 Jul 2010 18:40 #382938
by Patton
- moneypit
- Thank you received: 35
15 Jul 2010 20:00 #382968
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Z1-B Carb Overflow Hose Routing?
2-76 kz900
St Paul MN
16 Jul 2010 04:12 #383022
by Patton
Replied by Patton on topic Z1-B Carb Overflow Hose Routing?
Here's a rough idea of what the rubber piece looks like.
A suitable facsimile might be cut from a piece of inner tube.
- Kidkawie
- I bleed premix
16 Jul 2010 06:18 #383043
by Kidkawie
1975 Z1 900
2004 KX125
Sweet, thanks!
1975 Z1 900
2004 KX125
16 Jul 2010 09:20 - 16 Jul 2010 09:20 #383080
by Patton
kawasaki.com shows Part No. 92037-134 CLAMP,OVER FLOW PIPE as ACTIVE, and shared by 77 Kawasaki models, most recently being KL650EAF (KLR650) (2010).
Should be available through Kawasaki dealerships.
And maybe through Z1E.
Last edit: 16 Jul 2010 09:20 by Patton.
- Kidkawie
- I bleed premix
16 Jul 2010 09:28 #383081
by Kidkawie
1975 Z1 900
2004 KX125
Yeah, I already have the part, just forgot where it went. I was surprised to see it still available. Not that a zipty wouldn't work, but still, it's the details.
1975 Z1 900
2004 KX125
