vm26ss - missing part - what is it?
- atye
I found that one of the float bowls is missing a part that the other three bowls contain, but this part is not shown in the images that I have seen.
(Note: this is not my bowl, just a random image)
What is this part for and how critical is it?
Thanks,
Alex
1979 Kawasaki LTD1000 B3
Kerker 4-1 exhaust
Stock airbox
VM26SS carbs (115 main/17.5 pilot)
Corbin Gunfighter seat
Dyna-S ignition
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- atye
Would any harm come from running without this part on just that one carb?
Would it be noticeable?
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- atye
That isn't my bowl, just an image I snagged for an example. Mine has the hole and right now it is wide open. There is no circlip and no brass part inside.
Would this cause issues if the passageway is wide open and un-restricted? I am now thinking that it may cause the one carb to leak and/or possibly affect the other carbs since they are all linked.
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- dshelly
,dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- djcody
77 KZ650C airpods and 4 into 2 turn outs exhaust. VM carbs
82 550 LTD all stock except air pods
- DFIGPZ
- Thank you received: 122
yes there is a plunger retained by a spring w/o it your acc pump system would be in operative.Sorry, I didn't explain the photo correctly...
1984 750 Turbo
