RS34 Flat slide question
- kenskz1000
13 Jul 2010 13:26 #382315
by kenskz1000
RS34 Flat slide question was created by kenskz1000
I have read on previous posts that it is possible to adjust tension of throttle spring. My question is how. throttle is wearing out my right arm on rides
- hocbj23
- Visitor
13 Jul 2010 14:18 #382322
by hocbj23
Replied by hocbj23 on topic RS34 Flat slide question
Make sure throttle cable is lubricated as well as the carb linkage.Also,take the top off ur throttle housing and be sure the plastic cable guide is clean-I lube mine with some old "door_Eze" parafin stuff i had laying around.That might make ur life easier without messing with the throttle spring--u walk a fine line there between comfort and getting the carbs to close as they should.bj
- trianglelaguna
- Thank you received: 235
13 Jul 2010 14:20 #382323
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic RS34 Flat slide question
do you have the adjusters linkages set up to mimick a 1/4 turn set up......there are the links at the throttle itself which is where the final slack is set and then there is the carb end with its double 10mm nuts...i take almost all the slack out at the carb nuts and have it set that when very little handle bar/throttle link is taken up,then the throttle has a short throw/stroke imo....this keeps it snappy and also allows me to not be holding the extra cable open ...are you running only one throttle cable...this for me is the first step.......
1976 KZ900
2003 ZX12R
2007 FZ1000
- kenskz1000
13 Jul 2010 15:01 #382344
by kenskz1000
Replied by kenskz1000 on topic RS34 Flat slide question
Owners of these carbs have said in a previous post that the carbs themselves are adjustable and are set at stiffest setting from the factory. I want to know if they can be adjusted while on bike or on bench and how?
- davel
14 Jul 2010 23:32 #382787
by davel
Replied by davel on topic RS34 Flat slide question
The throttle return spring can be adjusted to different positions at the throttle linkage. Best to remove the carbs and look closely at where the two parts bear on one another.
Let me know if it still isn't clear after removing the carbs, I'll take a photo and post it.
- kenskz1000
15 Jul 2010 07:39 #382820
by kenskz1000
Thanks for all the help guys. I took them off and figured it out, much better now
