What is this outlet for?
- barquirt
13 Jul 2010 06:17 #382230
by barquirt
What is this outlet for? was created by barquirt
Good morning all.
I have a set of carburetors for a 1979 KZ650SR. They are the slide-type carburetor bank with an accelerator pump on the #2 carburetor.
On this set of carburetors, I have three brass nozzles/fittings. Two I recognize as the outlets for the overflow tubes, but there is a third brass nozzle on one of the carburetor bodies. What is this for? An extra drain? Or is to be linked up with something? Or capped?
When i have the carburetors installed on the bike and all the fuel lines, etc. attached properly i can't figure out what purpose this nozzle serves.
- JMKZHI
- Thank you received: 48
13 Jul 2010 06:41 #382231
by JMKZHI
Replied by JMKZHI on topic What is this outlet for?
Do a search for the fairly recent fuel line help topic in the Carburetor section. It has a photo of your carbs w the various ports labeled.
- H1Vindicator
- Thank you received: 53
13 Jul 2010 07:31 - 21 Feb 2013 20:50 #382237
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 21 Feb 2013 20:50 by H1Vindicator.
- PLUMMEN
- Thank you received: 104
13 Jul 2010 07:33 - 13 Jul 2010 07:34 #382239
by PLUMMEN
Replied by PLUMMEN on topic What is this outlet for?
cable/ dish network? got a picture? :laugh:
Last edit: 13 Jul 2010 07:34 by PLUMMEN.
- barquirt
13 Jul 2010 08:18 #382247
by barquirt
Replied by barquirt on topic What is this outlet for?
Really? The petcock vent line attaches to a carburetor? I thought it was routed to one of the four outlets on the intake boot.
I will try this setup tonight and see if I have success.
- JMKZHI
13 Jul 2010 08:44 #382256
by JMKZHI
barquirt wrote:
Actually, the petcock has a vacuum port - it's not a vent. It shouldn't matter whether you connect it to the carb vacuum port or carb-holder vac port. Whichever one isn't used should be capped. If the other carb holders have unused vacuum nipples, they should be capped as well.Really? The petcock vent line attaches to a carburetor? I thought it was routed to one of the four outlets on the intake boot....
- Thank you received: 2098
13 Jul 2010 13:03 #382313
by Patton
