Please help!! Mikuni Problems
- kzbobber1
16 Jul 2010 06:52 #383050
by kzbobber1
Replied by kzbobber1 on topic Please help!! Mikuni Problems
Here are some pictures of my carbs, including a pic with the missing triangle piece. I just need to know what they are and what they came off of so I can buy the part I need that is missing. I also need to know what to do about the jets. I have an 82 kz750E running pods so what would be the best jet to start with? They measure 24mm on the engine side and 35mm on the intake side. Thank you for all your help.
- kzbobber1
16 Jul 2010 06:53 #383051
by kzbobber1
- kzbobber1
16 Jul 2010 06:54 #383052
by kzbobber1
- kzbobber1
16 Jul 2010 06:54 #383053
by kzbobber1
- kzbobber1
16 Jul 2010 06:55 #383054
by kzbobber1
- kzbobber1
16 Jul 2010 06:56 #383055
by kzbobber1
- anarki650
- Thank you received: 5
16 Jul 2010 07:15 #383057
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Please help!! Mikuni Problems
Those are vm24 carbs with accelerator pump. They came on the kz650 from 79-81 (82 saw Kaw switch to CV carbs on the kz650). They look just like the stock set off the 81 650 CSR I had a couple years back. Those carbs didn't have anything on that spot where you're trying to find the missing piece. As mentioned previously that "mount" is actually a blocked off dummy and nothing was ever supposed to attach there (assuming they are kz650 carbs and not from some other make like a Suzuki or such).
09 Kawasaki ER6n
Omaha NE
- otakar
16 Jul 2010 07:27 #383059
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Please help!! Mikuni Problems
For a KZ750 those are very small carbs. They will be fine for every day riding but very poor economy and no power. Kawasaki put larger carbs than that on the 82 400 four cylinders.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- pz1morton
16 Jul 2010 09:53 #383083
by pz1morton
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
Replied by pz1morton on topic Please help!! Mikuni Problems
Yes those carbs are from a 76-78 kz650 that did use an accelerator pump, kzbobber1.use should be using a set of mikuni 34mm cv carbs,that will wake up that engine.they are usualy found on GPZ750's.
Regards Paul
Regards Paul
1984 GPZ900
- kzbobber1
16 Jul 2010 10:45 #383096
by kzbobber1
what would be the best ones for me to run on my bike then? where can I get these? thank you
- anarki650
16 Jul 2010 18:56 #383227
by anarki650
09 Kawasaki ER6n
Omaha NE
Keep your eyes open here in the classifieds and watch ebay. You're wanting to find BS34 Mikunis. Search ebay for kz1000 police carbs, or GPZ750 or 1100 carbs. The 1000 or 1100 carbs will need to be jetted appropriately for the 750 motor, but will work perfectly once you get the jetting figured out.
09 Kawasaki ER6n
Omaha NE
- kzbobber1
17 Jul 2010 11:27 #383337
by kzbobber1
I measured my carbs again just to be sure, they measure just slightly over 1 inch, which says that they are 26mm not 24. I took out the main jets last night and they say 92.5 on each one of them. First and foremost will these carbs work on my 750 just for a cruiser? The walls are quite thick and Im sure I can bore them out to about 30mm or better pretty easily. Second, if I am running pod filters what would be a good jet to start off with? I am going to buy a few different ones so I dont have to run back to the store to get it right, but wanted to know what a good number would be as a starting point. Someone told me 102 but I dont know. Thanks
