- Thank you received: 2098
inconsistant plugs
12 Jul 2010 07:01 #381928
by Patton
Replied by Patton on topic inconsistant plugs
Could test run without pods to determine whether pods are blocking entrance to pilot air passage.
- asevans
12 Jul 2010 09:54 #381973
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
Replied by asevans on topic inconsistant plugs
Patton.. How does certain pods block the entrance to pilot air passage?
1978 Z1-R Project
12 Jul 2010 11:01 - 12 Jul 2010 11:02 #381991
by Patton
I don't run pods, but have seen several threads here on KZR where reportedly some cheap pods (not K&N) on some carbs managed to partially obstruct the small entrance hole to the pilot air passage.
That's why it might help diagnosis to test run without the pods.
Last edit: 12 Jul 2010 11:02 by Patton.
- asevans
12 Jul 2010 11:29 #381996
by asevans
1978 Z1-R Project
well that could be why i dont get much change in my air screw. i just cleaned my carbs really good. paying special attention to the pilot air circuit.
i get rough idle when i screw them out to about 2 turns and when i close them all the way down. but in between not much change.
looked at the the nice K&N air pods but damn 150 Bucks. thought it might be just as well to buy an airbox.
been watching ebay. i dont have any of the airbox parts. bought the bike with pods. the cheepest of pods. im not sure what to do. going to get the valve clearances squared away first. then check my compression. check my voltage to coils. get all that right and go from there.
thanx for all the help.
1978 Z1-R Project
12 Jul 2010 11:37 - 12 Jul 2010 11:39 #381997
by Patton
Where pilot screw adjustment fails to change rpm, there's likely something still wrong inside the carb.
If this method hasn't already been tried for cleaning pilot circuit, it might succeed where others have failed.
[Click on image to enlarge view.]
Last edit: 12 Jul 2010 11:39 by Patton.
