29 smoothbores help wanted
- cracker0
11 Jul 2010 15:55 #381747
by cracker0
75,z1b,34 rs,cams,porting,k+n,dyna2 and 4 into 1.
29 smoothbores help wanted was created by cracker0
hey all,
was curious if anyone mite know what the heck is goin on!29 smoothbores on a 75 z1b,1075 cc,stage one porting,10.5:1,.418 lift cams,4 into 1,and k+n's.stock valves.
pilot 22.5
needle .06
needle jet5dl31
slide 2.mm
air jet 0.9
needle clipped at 3
slides are supossed to be 1.5mm for a kawasaki.
now it seems to idle ok,but when ya give it gas about 2300 rpm it jets up to about 5000rpm and will not idle down till i adjust the idle screw.did spray wd lookin for leaks,none found.bike lives at 4300 ft.above sea level.at a lost on this,any ideas would be helpfull.
thanks jc
pilot 22.5
needle .06
needle jet5dl31
slide 2.mm
air jet 0.9
needle clipped at 3
thanks jc
- PLUMMEN
- Thank you received: 104
11 Jul 2010 15:57 #381749
by PLUMMEN
Replied by PLUMMEN on topic 29 smoothbores help wanted
id start with vacuam leak or cable hanging up before going into the carbs
- cracker0
11 Jul 2010 16:03 #381751
by cracker0
Replied by cracker0 on topic 29 smoothbores help wanted
linkage is not connected.do ya install intake manifolds dry or with silicon.
- PLUMMEN
11 Jul 2010 16:11 #381756
by PLUMMEN
i smear silicone on the head mating side(boos/hisses from audience! :laugh: )look on inside of boots for the cracks
- cracker0
11 Jul 2010 16:18 #381760
by cracker0
so the jetting has nothing to do with this?ever seen this before?what bout the slides,to big?thanks for the info!
