pretty simple question, need answer.
- 4rugrat1
- 2006hhr
- mark1122
- Keep twisting it
- Thank you received: 109
u can put some tape around the grip and mark off these positions before a test ride.
Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
Just in case.... How to Read Your Spark Plugs...
kzrider.com/index.php?option=com_docman&...d&gid=460&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
i have a kz650 v&h header, i rejetted it to where above 6k, the bike pulls great, but under 6k the bike has a stutter and slug, it has 107.5 main jets, and the needle is 4th clip. if i take the air filter out of the bike, it runs perfectly, should i go one size down on main jet? or should i move my needle clip to stock?
Return jet needle clip to stock (presumably middle) position, as the jet needle and needle jet largely determine air/fuel mixture during throttle mid-range, where main jet size has very little effect.
Influence of main jet size is mostly at wide open throttle and near WOT.
Jet needle clip position has virtually no influence at WOT, where main jet size and needle jet are controlling mixture, and jet needle is no longer restricting fuel through needle jet.
- leakyseal
- KZ pilot for life.
You still running an airbox? :huh:i have a kz650 v&h header, i rejetted it to where above 6k, the bike pulls great, but under 6k the bike has a stutter and slug, it has 107.5 main jets, and the needle is 4th clip. if i take the air filter out of the bike, it runs perfectly, should i go one size down on main jet? or should i move my needle clip to stock?
Quit wasting that V&H pipe and...
GO BUY SOME PODS SOLDIER !
Mission briefing:
-Aquire four pod filters and crankcase vent filter.
Note:
These pods can be purchased in sets.(K&N makes nice
ones).Attach vent filter to the hose that went to your
airbox,or get a new hose.Ziptie it somewhere high.
Don't mount this small filter right on the crankcase
where it looks so nice,oil will escape.
-Place the clip on middle position.
-Return air/fuel screws to midpoint.
-Dial in the jetting if needed(averge temp day only)
Note:
Expect remove the carbs several times on this mission.
Your 3 targets are as follows.
-pilot jet/air-fuel screws (idle-1/3 throttle)
-Needle (mid throttle)
-Main jet(wide open)
WHY ARE YOU STILL HERE MAGGOT !
EQUIP THAT KZ ,KILL THE ENEMY ! :woohoo:
i have a kz650 v&h header...needle is 4th clip. if i take the air filter out of the bike, it runs perfectly, should i go one size down on main jet? or should i move my needle clip to stock?
Besides returning carbs to oem configuration, would also fit a brand new air filter (if not already done).
