uh oh... idles low, throttles high....??????
- kz.chris
Background: I rebuilt a set set of carbs i got off ebay. I tore them completely down and cleaned everything. new o-rings and gaskets. I did not replace the jets.
**i have not yet used a gauge to sync the carbs while on the bike**
I am able to get the bike fired up very easily even with the choke lever down (is this a problem?)
The problems:
When i start the bike i will adjust the air/fule mixture so its idling around 1.5 rpm. the bike sounds pretty good. No revving then dropping or popping. No white smoke, no black smoke.
BUT when i take the bike around the neighborhood it rides great for the first half of the trip (maybe 4 blocks) but then out of no where the RPMs start to creep up every time i pull the clutch in. it gets to the point where the only way to get the RPMS down is to turn back the air/fuel mixture again...
Im thinking i did not set up the throttle cable correctly but at this point im just looking for any thoughts or suggestions.
thanks a lot
1977 Kawasaki KZ650
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Part of a good carb rebuild is making sure the fuel heights are all correct, and a good manual sync.
This is a must, and makes a huge difference in the idle, cruise, and power output.
Not necessarily. You could be a little too rich, but a nicely tuned bike will start without choke if it has been sitting in the HOT sun on a real hot day.
OK... so... when you say air/fuel mixture... do you mean the large idle control knob, or are you adjsuting the small screws (4) on each carb?
Sounds like either air/mixture screws not properly adjusted, or an air leak at one of the carb holders.
Try: adjusting the idle control knob so the bike idles at 1000 rpm. Then starting with all the mixture screws at 1.5 turns out from lightly seated, turn all of them out another 1/4 turn. If the idle rises, then continue to turn further. If idle drops, turn them all the other way.
Youre trying to find the highest idle point.
At some point turning the screws either way some will result in the idle dropping if everything is setup good.
This is a rough way to tune the screws, but it will get you running/close.
Let us know!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kz.chris
Today i started the bike and turned the air/fuel mixture screws (one by one) on each carb inward. The bike starts to die if i dont back out the screws quickly.
I backed each screw out 2 1/2 turns.
Took the bike for a spin and ive pin pointed whats going on.
The rpms climb and then stick every time i pull the clutch. when i release the clutch the rpms slowly drop if at all. by the time i got back to the drive way they were sticking at 4k
I double checked all connections and from what i can tell every thing is tight to the engine and airbox.
any ideas??
1977 Kawasaki KZ650
- Thank you received: 2098
The inconsistent idle may result from an air leak at wherever.
At idle, would spray WD40 all over suspected leak areas, such as carb holders, clamps, vac plugs, and look for smoke from the exhaust due to ingesting WD40.
- kz.chris
Air/fuel mixture crews should be adjusted only after engine has attained normal operating temperature. And not right after it's started.
Thanks ill give that a try
1977 Kawasaki KZ650
- kz.chris
I wont really know if everything is working properly until i get the sync gauge.
1977 Kawasaki KZ650
- TeK9iNe
Fortunately, making things air tight is pretty easy. Especially if you use some permatex Moto-seal.
Once the bike is hot and running with no choke, use the idle control knob to get it down to around 1000 rpm.
Then turn all 4 mixture screws at the same time/the same amount, and you will hear a deffinate change in the rpm. it will go up or down. Just keep turning them all in succession till you pinpoint the highest idle point, then leave it.
Vac sync once this is done, will make a big difference.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
