1977 mikuni kz650 : Throttle slide clearance?
  • kz.chris
  • kz.chris's Avatar Topic Author
09 Jul 2010 14:55
#381315
One thing I didnt pay attention to when rebuilding my carbs was the throttle slide clearance setting.
I dont have a manual. Does any one have this info?
Thanks
Chris
1977 Kawasaki KZ650
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: 1977 mikuni kz650 : Throttle slide clearance?
09 Jul 2010 18:26
#381363
Not sure what you mean by throttle slide clearance?
Do you mean the default gap?
If it slides nicely and doesnt rattle around or get hung up, your ok.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kz.chris
09 Jul 2010 18:28
#381364
Peace.
B)
Thanks for your time.
I mean the gap from bottom of the slide when the throttle is closed. There is an adjustment screw at the top of the slide that sets the "height" of the slide allowing a gap at the bottom. One side of the slide (the engine side i think) has a deeper round edge than the other.
1977 Kawasaki KZ650
  • anarki650
  • anarki650's Avatar
09 Jul 2010 18:31
#381365
About any specs and procedures you could ever want to get your grubby little hands on over on www.kz650.info in the maintenance section. Here's a link:
maintenance.kz650.info/GeneralMaintGuides.php
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • kz.chris
09 Jul 2010 18:35
#381366
amazing thanks!
1977 Kawasaki KZ650
  • CLJ_LightRide
  • CLJ_LightRide's Avatar
21 Sep 2010 01:18
#400503
okay, i have a 1977 kz650 b3 with some questions about things on the carb and questions about tuning the bike. first of all what do i do with those bypass air hoses (i think) when i have pods on it. second i start the bike it runs. i roll the throttle 1 ~ 2 mm no big deal 3 and it try's to choke out. any ideas? the jets in it are whatever z1enterprises gave me for carb rebuild kit (did not specify weather it was for airbox or pod so i am assuming its for airbox. do i need to get different jet and pilot? pictures attached are my carb and a diagram my carb is the one on the right.
  • CLJ_LightRide
21 Sep 2010 01:20
#400504
another thing
  • CLJ_LightRide
21 Sep 2010 01:21
#400505
yet another
  • CLJ_LightRide
21 Sep 2010 01:21
#400506
and last one
  • CLJ_LightRide
21 Sep 2010 02:00
#400507
okay, so i finally found what i was looking for in my book... next question... what size pilot screw and main jet (and is there another one) should i use i have stock 4 in 2 pipes with pod filters.
  • Injected
  • Injected's Avatar
23 Sep 2010 17:36
#401284
If stock main jet is 102, then just with the pods go to a 105... you don't have to change the pilot. Adjust your air screws to where you can smoothly take off from a stop. Do a plug chop at 6000 RPM and take a look at the plugs to see if that main jet setting is OK.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
