installing rebuilt carbs: air box on or off?
- kz.chris
08 Jul 2010 22:03 #381212
by kz.chris
1977 Kawasaki KZ650
installing rebuilt carbs: air box on or off? was created by kz.chris
I'm about to install "new" carbs into my bike and im wondering if i should put the airbox back on for the initial startup or do i leave it off so i can spray starter fuel into the carbs?
Also, any recommendations before i go fire her back up?
thanks
thanks
1977 Kawasaki KZ650
- TeK9iNe
- What did you do!?!
- Thank you received: 28
08 Jul 2010 23:34 #381220
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic installing rebuilt carbs: air box on or off?
NO STARTER FLUID. Thats what the gas is for.
Yes airbox. It provides the necessary resistance/filtration for the proper operation of the carbs.
Make sure EVERYTHING is air tight!
If everything is correctly setup, the bike will come to life very easily. Full choke, depress starter and bang, she'll roar to life.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kz.chris
09 Jul 2010 06:43 #381250
by kz.chris
1977 Kawasaki KZ650
Replied by kz.chris on topic installing rebuilt carbs: air box on or off?
Excellent. Thanks.
1977 Kawasaki KZ650
- mtkawboy
- Thank you received: 16
09 Jul 2010 08:57 #381257
by mtkawboy
Replied by mtkawboy on topic installing rebuilt carbs: air box on or off?
With carbs rebuilt & jetted stock you will think you have some major problems if you run them without the airbox, as in it will barely run at all.
- cobura
- forever 2 wheels
- Thank you received: 3
09 Jul 2010 10:47 #381268
by cobura
1979 KZ650B3
Replied by cobura on topic installing rebuilt carbs: air box on or off?
also, you probably wouldnt be able to get the airbox back on without taking the carbs off again
1979 KZ650B3
