Help with carb id
- Mac68
08 Jul 2010 17:22 #381153
by Mac68
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
Help with carb id was created by Mac68
First want to say thanks for a great site with lots of good info. I bought a 1980 kz 1000 b4 ltd about a week ago with 7,700 original miles. The po had put a new set of carbs supposedly off the kaw dealers shelf they are Mikuni with id mark 299 no pump they do look pretty new and run good. Was wanting to know if anybody could help me with what they are in case i ever have to work on them. I also have the original set that should be vm 28's with pump id 120 over 2 is that correct? Thanks for any and all help.
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
- keith1
- Thank you received: 2
08 Jul 2010 18:05 #381162
by keith1
Replied by keith1 on topic Help with carb id
pics go a long way in helping.....
- Mac68
09 Jul 2010 09:58 #381263
by Mac68
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
Replied by Mac68 on topic Help with carb id
[/img]
[/img]
Here are a couple of pics of the ones on the bike. I think i figured out the other ones are vm 28 pumpers the have 102.5 mains and 15 pilots.
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
- Mac68
09 Jul 2010 10:01 #381265
by Mac68
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
- keith1
09 Jul 2010 11:10 #381272
by keith1
could be 26's....
- Mac68
11 Jul 2010 10:11 #381666
by Mac68
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
Ok thanks Keith that is sorta where i was leaning to that they might be 26's.
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
- Old Man Rock
- Thank you received: 225
11 Jul 2010 10:25 - 11 Jul 2010 10:30 #381667
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Help with carb id
Measuring them would give you the exact metric but maybe this will help as well....
Hard to see in your images... Over-flow nipple out the float bowls? If so then I'm with Keith, 26mm....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Jul 2010 10:30 by Old Man Rock.
- Mac68
11 Jul 2010 15:35 #381736
by Mac68
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
Yes over flow nipples out of the float bowls. I'll measure them for sure when and if i have any problems and have to pull them off. She is running great right now just wanted to try to figure out what they were for sure in case i have to order anything for them.Thanks Old Man Rock for the info!
Oklahoma
1978 KZ1000 A2
1980 KZ1000 MKII
- TerryK
- Thank you received: 3
11 Jul 2010 20:51 #381853
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Help with carb id
Look like stock KZ1000 VM26 to me.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- elira2878
22 Jul 2010 20:01 #384762
by elira2878
1980 KZ1000 LTD
1981 KZ440 LTD
1974 CB550
Replied by elira2878 on topic Help with carb id
Can you send this image to me? I have a carb i need to identify also. elira2878@hotmail.com
1980 KZ1000 LTD
1981 KZ440 LTD
1974 CB550
