I've Just Dropped The Bowls On A Set Of Mikuni...
- glennhudson
- Art, science & people.
08 Jul 2010 12:04 - 08 Jul 2010 12:07 #381088
by glennhudson
multiple media art * shoot & edit video * compose text & music
I've Just Dropped The Bowls On A Set Of Mikuni... was created by glennhudson
...Kogyo's I just purchased.
They have the Accelerator Pump.
2 questions.
1.) Where on the carbs do I measure to determine the size?
2.) Is there an online reference for proper specs upon (post-cleaning) reassembly?
2 questions.
Last edit: 08 Jul 2010 12:07 by glennhudson.
- Thank you received: 2237
08 Jul 2010 12:24 #381100
by TexasKZ
Replied by TexasKZ on topic I've Just Dropped The Bowls On A Set Of Mikuni...
1) Inside diameter of the main bore on the airbox side.
2)Depends. What bike? Are these the stock carbs for that bike?
- otakar
08 Jul 2010 12:35 #381104
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic I've Just Dropped The Bowls On A Set Of Mikuni...
Give us some info about the bike and we can most likely tell you what they are. And it is the Engine side you measure not the airbox side.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JMKZHI
- Thank you received: 48
08 Jul 2010 12:46 #381108
by JMKZHI
Replied by JMKZHI on topic I've Just Dropped The Bowls On A Set Of Mikuni...
VM24 carburetors measure 24mm on either side of the throttle slide. On the engine side opening, they measure ~26mm ID.
- glennhudson
27 Aug 2010 00:05 #394135
by glennhudson
Replied by glennhudson on topic I've Just Dropped The Bowls On A Set Of Mikuni...
thanks for all the input guys.
various parts purchase and assembly went smoothly.
would anyone car to chime in on this one?
kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=392476
