kz440 jetting
- qualitylawns05
07 Jul 2010 17:58 #380873
by qualitylawns05
kz440 jetting was created by qualitylawns05
hello everyone,
Im new to the site and somewhat new to motorcycles in general. I have a quick question and i hope someone has an answer for me. I bought a 1981 kz440 about 3 months ago. When i got it, it didnt run at all. I took the carbs all apart cleaned them up and got it running pretty well but now i put the individual air pods on it and i was wondering if someone could give me an idea as to what size jets i should use for the increased air coming in. Now i do not know what is in there right now and i have heard to go 25%bigger of a jet but to me that means nothing. lol, I can do the work myself but when it comes to the sizes i have no knowledge. I hope someone can help!
- Nebr_Rex
- Thank you received: 300
07 Jul 2010 20:09 #380932
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic kz440 jetting
have you done a compression test,adjust the valves,tune up?
look in the filebase for the specs
try 4% larger than stock to start with
so if the stock main jet is 100 try a 105
most jets for the carbs used on KZs are sized in 2.5 increments
then you'll have the jet needle and pilot jet to play around with
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Jul 2010 20:46 #380950
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic kz440 jetting
qualitylawns05 wrote:
Yes... and now your @#$%ed! :laugh: :laugh: :laugh:
SERIOUSLY though... put the origional airbox back on until you have the thing running in excellent condition.
Set proper valve clearances.
Check cylinder compression.
Check carburetor fuel/float levels.
Make absolutely sure there are no air leaks anywhere.
Set timing dead on.
Use a proper manometer to perform (VERY NECESSARY) vacuum syncronization of the carburetors.
Tune the mixture screws correctly.
GET THE MANUAL, it saves its weight in gold!
GL! man...
Do it.
Set timing dead on.
GL! man...
Do it.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JMKZHI
- Thank you received: 48
08 Jul 2010 06:24 #381003
by JMKZHI
Replied by JMKZHI on topic kz440 jetting
To reiterate the previous reply...
According to a number of knowledgeable folks including some Kaw mechanics, the KZ440 w stock carburetors is virtually impossible to tune with pod filters. So, reinstall the airbox & treat it with kid gloves - 440 airboxes seem kinda rare & the cap is even rarer still. Or do whatever you want.
- qualitylawns05
09 Jul 2010 16:57 #381345
by qualitylawns05
Replied by qualitylawns05 on topic kz440 jetting
thanks everyone. I think I might just take it to someone who will take care of it for me. Thats getting in a little deeper than i wanted. lol. The stock airbox is not gonna happen anymore. Its now ridgid frame and stretched 8 inches. Im going to finish the frame and body work and take it to a shop around here to get it running in top shape. When it comes to motors im not the smartest person. ill post some pictures when i can for everyone to see it.
