- Thank you received: 2
Keihen CV34 Sync
- kz750saskatoon
06 Jul 2010 20:36 #380705
by kz750saskatoon
1981 KZ750-H2
Saskatoon, SK
Keihen CV34 Sync was created by kz750saskatoon
I am about ready to put my carbs back on the bike after running into an issue of the #3 cylinder not firing.
I have adjusted the float levels and they are good now. One bowl is leaking a drop of fuel every so often but I think that might be a bowl or drain screw issue.
My question is about bench syncing/vacuum syncing the CV34s. In other threads I have read that the adjustment involves the height of the slides. From what I have seen on the CV34s, the synchronization is actually changing the opening of the throttle butterfly valve. Am I correct on this?
If that is what I am trying to do, how should I bench sync the carbs? An old thread that came up with a search here is so just a sliver of light is visible through at the top and bottom of the butterfly valve. Is this right? I have heard of using a very small wire to get them all similar. Can someone comment on that?
My bike has not been operational in far too long. I need to get out on the road real bad!
1981 KZ750-H2
Saskatoon, SK
- nads.com
- Thank you received: 20
06 Jul 2010 22:16 - 06 Jul 2010 22:21 #380718
by nads.com
Replied by nads.com on topic Keihen CV34 Sync
I would not relay on the light. The wire will work fanstastic. You must make sure that you can see the idle mix holes (engine side)that they are all partially and equally exposed to the engine side. Back off the idle screw until all butterflys are closed. Turn the screw in until you see about a fourth of each of the holes inside the carbs throats on the engine side. If any are open more or less than the others, adjust the synch screws untill they all are equal. Double check your work with the wire. DONE Except! Maybe you want to put your mouth around each carb and suck. Do they all feel the same? No? What do u do? Ask Larry Caven if u can borrow some tools to straighten out some F L O W. Bet if you syched them that way they would be super accurrate, and if any vaccuum was uneven at further openings, It's the engines fault. If the opening are not equal, adjust the butterflys that are open farther by closing them to mathc the rest. If you open the ones most closed it can cause a high idle that will piss you off tho no end. :woohoo:
Last edit: 06 Jul 2010 22:21 by nads.com.
- JR
- Thank you received: 449
07 Jul 2010 14:22 #380835
by JR
Replied by JR on topic Keihen CV34 Sync
I have the same CV34 carbs but have never tried to bench synch. I've always gone straight to the vacuum gauges as I think bench synch is just to get them in the ball park before a full and proper synch.
You are correct regarding the opening of the throttle butterflies - no throttle slides in these carbs - but the tiniest change in the opening has a big effect. It's like that with the vacuum gauges. I would try to "tiny smidgen of light" approach or perhaps a very fine wire like a 1st guitar string or smaller if you can get one
With a tiny opening of the butterflies I would expect a high idle when you put the carbs on the bike as they are normally fully closed at idle.
Let us know how it goes ......and good luck
- kz750saskatoon
07 Jul 2010 21:58 #380960
by kz750saskatoon
1981 KZ750-H2
Saskatoon, SK
Replied by kz750saskatoon on topic Keihen CV34 Sync
So I finished it up but I wanted to verify that I did it right. It seemed like there was no adjustment screw for Carb #2 like there was for the other 3. I ended up using the idle thumbscrew to set the throttle plate for #2 then used the adjusters between the other carbs to do the rest. Does this sound right?
Never got a chance to try it out as I set one of the floats way too high. Luckily it was one of the outside guys so I didn't have to take the rack off to get the bowl off.
Getting the rack on is SO much easier with new air boots and carb holders. Wow.
1981 KZ750-H2
Saskatoon, SK
- JR
08 Jul 2010 15:23 #381132
by JR
Sounds like you're on the right track.
Yep, thats it. No adjustment screw on the #2 carb. Everything is synched to #2.
Good luck
Good luck
- kz750saskatoon
12 Jul 2010 07:23 #381932
by kz750saskatoon
1981 KZ750-H2
Saskatoon, SK
Got the bike on the road yesterday. Thanks for all your help!
1981 KZ750-H2
Saskatoon, SK
- kz750saskatoon
16 Jul 2010 10:43 #383094
by kz750saskatoon
1981 KZ750-H2
Saskatoon, SK
New question related to float/fuel level check. I am getting a steady drip of fuel out of the overflow of carb #4. I think the brass tube is okay as I removed the bowl, filled it with water at the sink and checked and it didn't leak. After thorough drying I put it back on the bike.
When I checked the fuel level using a clear tube, the level was approximately 4mm below the bowl gasket, which is the spec. I am doubting this measurement though. When I unscrew the drain screw the fuel would start to come up but then there would be an air pocket right at the drain/overflow nipple. The fuel level in the tube would be very low (~2 cm). If I tapped the tube eventually the air bubble would work its way back into the carb and more fuel would come out.
Is the measurement off due to this bubble? It happened on all four carbs so initially I dismissed it and assumed the final reading was correct.
Needle seems to seat well because if I take the bowl off and hold the floats up and turn the petcock on, no fuel comes out.
A little confused as to what to check at this point.
1981 KZ750-H2
Saskatoon, SK
- JR
16 Jul 2010 17:48 #383188
by JR
Is it a vacuum petcock and do you have it set at on - not prime - when you are dong this ?
Bubbles can screw up reading the levels. When I have a bubble I either tap the tube to move the bubble or lower the tube with finger over the opening and move the bubble back up into the carb and then raise the tube again and let the level settle. Hopefully you just have the fuel level to high.
Constant drip could be the float valve and seat. I dont know if holding the floats up is a good test. I have taken the carbs off, taken the float bowls off held them upside down and blow into the fuel line and see if air escapes at the float valve. You could try cleaning the brass valve seat with a Q tip dipped in carb cleaner. Mine were so bad once that I had to dip the Q tip in Brasso - worked.
- mark1122
- Keep twisting it
- Thank you received: 109
17 Jul 2010 08:17 - 17 Jul 2010 08:17 #383306
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Keihen CV34 Sync
sorry but i nothing to add that hasnt been said.
i do have a question for another member though.
what is the float hight, and fuel level spec for the bs34, and cv34 carbs?
is the fuel level measured from the bowl gasket surface?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 17 Jul 2010 08:17 by mark1122.
- JR
17 Jul 2010 09:59 #383316
by JR
Mark
The Haynes manual for the 750s says:
Keihin CV 34 carbs fuel level 4 +/- 1mm.
No spec for float height
Mikuni BS 34 carbs fuel level 3 +/1 1mm
Float height 18.6mm
Float height 18.6mm
- mark1122
- Keep twisting it
17 Jul 2010 16:53 #383410
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
thanks JR.
i'll pass that info on.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kz750saskatoon
18 Jul 2010 08:48 #383598
by kz750saskatoon
1981 KZ750-H2
Saskatoon, SK
I had the petcock set to prime when I was checking the level. Is this not correct? I kind of thought it would have to be set to prime otherwise the fuel level in the carb wouldn't be able to settle to its "final" level.
I did clean out the float valve seats with a Q tip and carb cleaner when I had them apart. I may try rechecking the level by covering the hole and moving the tube like you said you do.
1981 KZ750-H2
Saskatoon, SK
