- Thank you received: 1
3000 RPM SPUTTER
- cstm700ltd
06 Jul 2010 18:04 - 06 Jul 2010 18:06 #380676
by cstm700ltd
1985 LTD 700 custom paint, lowered suspension, custom ground cams, side exit exaust etc...
3000 RPM SPUTTER was created by cstm700ltd
When ever im riding at a steady speed like 50mph for a little while and i try to give it some more gas to speed up my bike will lag and fall down for a second and pick back up but its driving me crazy so is it that the carb jets need to be replaced or ???
i just recently had the new exhaust put on and it didnt do it before so thats probably why but im not a carb guy
any iedas??
any iedas??
Last edit: 06 Jul 2010 18:06 by cstm700ltd.
- bountyhunter
- Thank you received: 337
06 Jul 2010 18:23 - 06 Jul 2010 18:25 #380684
by bountyhunter
Replied by bountyhunter on topic 3000 RPM SPUTTER
Can't see in the photo, are you running pods?
If not, sounds like you need larger main jets and possible to lift the needles a bit to compensate for the extra air going through the new headers..
ADD: I just noticed those look like straight pipes. You will need a ton more main jet and get used to the idea it will never run right again.
Last edit: 06 Jul 2010 18:25 by bountyhunter.
- MFolks
- Thank you received: 540
06 Jul 2010 18:27 #380686
by MFolks
Replied by MFolks on topic 3000 RPM SPUTTER
Does your bike have the mechanical ignition advancer? Look on the right side of the engine for a CD sized cover. The advancer is secured to the end of the crankshaft, it advances/retards the timimg by using weights and springs.
To check it(with the engine off), give it a twist, if it does not return, remove it, and clean/lubricate it with some 3-in-one or sewing machine oil.
If the advancer works ok, check the sparkplug wires,sparkplugs and sparkplug caps.
- The Duke
06 Jul 2010 18:29 #380688
by The Duke
Replied by The Duke on topic 3000 RPM SPUTTER
Whenever we added Headers to our bikes, the first thing we did was drill holes in the air-box under the seat. When the exhaust is free-flowing, then your carbs are sucking more air, more air equals more fuel. When you down shift (using the engine as a brake) it shouldn't pop. If it pops when you down shift, then you need to go up one jet size. A good mechanic can drill it out - but let them do it. don't go crazy on the jets. Good Luck.
- cstm700ltd
06 Jul 2010 18:45 #380689
by cstm700ltd
Replied by cstm700ltd on topic 3000 RPM SPUTTER
allright thanks alot guys im going to take it to a local motorcycle shop to have them do it and yes its straight pipe because "loud pipes save lives" and it definatley noticeable
so just drill into the top of the air box to allow more air?
i was also wanting to run single air filters on each carb for looks but would that help out with the air flow as well?
- The Duke
08 Oct 2010 19:26 #405341
by The Duke
Try drilling holes in the airbox first and see what it does. I'm willing to bet it runs fine.
- Thank you received: 2829
08 Oct 2010 19:39 #405347
by 650ed
Replied by 650ed on topic 3000 RPM SPUTTER
cstm700ltd wrote:
"yes its straight pipe because "loud pipes save lives" and it definatley noticeable"
Oh boy, here we go again. :laugh: :laugh:
- hal0tw0
- Thank you received: 4
11 Oct 2010 04:40 #405901
by hal0tw0
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
Replied by hal0tw0 on topic 3000 RPM SPUTTER
my bike does the same but at 4-4.5k when I roll on throttle to pass someone. It hesitates bad then it just launches when I go past 3/4 trottle.
Im gonna go through the carbs at some point and post whats in there.
- Old Man Rock
- Thank you received: 225
11 Oct 2010 05:26 #405906
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 3000 RPM SPUTTER
Open pipes and pods usually would indicate more air then gas so running too lean on the needle size at mid range....
You can try a richer clip position on the needles first but best guess at the moment (not enough info such as idle and main operation states as well as plug conditions), change to richer sized needle...
Here... everything you need to know/learn about carbs....
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
