help! removing carbs from assembly
- kz.chris
ive gotten it pretty loose but it seems stuck in these 2 places
1977 Kawasaki KZ650
- keith1
- Thank you received: 2
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- kz.chris
I want to remove all rubber and other pieces that will not survive the carb cleaner bath.
1977 Kawasaki KZ650
- keith1
i want them off the rack so i can soak and soda blast all the components.
remove the screws holding them onto the rack on the side facing the intakes and just yank em apart....
- kz.chris
its not quite that easy just to pull it apart. feels like im forcing it
1977 Kawasaki KZ650
- MFolks
- Thank you received: 540
It will take longer than using a solvent cleaner, but no nasty fumes to inhale.
- kz.chris
you have to remove all the screws from the back of each carb then it all just falls off.
i was only removing one at a time.
thanks!
1977 Kawasaki KZ650
