#3 cylinder not quite right
- chrispysaki
06 Jul 2010 09:32 #380566
by chrispysaki
#3 cylinder not quite right was created by chrispysaki
I've got my bike running pretty well, but the last couple rides I've noticed that the head pipe from the #3 cylinder isn't as hot as the others. The other three are so hot that I can only touch them for split second. The #3 pipe is still very hot, but I can still touch is for a good second or two. I checked the plug and it's leaner than the others, so I'm clearly getting spark. Could it be that the gap is too big and there's too much spark?
All four cylinders were running a little on the lean side, so I've been backing out the pilot screws trying to richen it up. Now the 1, 2 and 4 look plugs have a nice tan color to them, but the #3 is still white.
I assumed that the leaner it is, the hotter the pipes get, so I'm a little confused why the leanest cylinder would also have the coolest pipe.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
06 Jul 2010 09:49 #380568
by Skyman
West Linn, OR
Replied by Skyman on topic #3 cylinder not quite right
You actually touch your exhaust headers to tell if they are hot or not? :ohmy:
Next time, try using a spray bottle with water, or a laser thermometer. :blink:
I'm not sure why you'd get the coolest pipe on the leanest cyl. Maybe someone else can figure that one out.
West Linn, OR
- chrispysaki
06 Jul 2010 20:20 #380703
by chrispysaki
Replied by chrispysaki on topic #3 cylinder not quite right
Yeah, I know I shouldn't, but I guess I'm too lazy to grab a spray bottle. I should clarify, though, that I definitely can't touch the #3 pipe for a second or two - more like .1 seconds compared to .05 seconds for the other pipes. It might not seem like much, but there's a definite, noticeable difference in temperature. I guess I'm being nit-picky here, but it just seemed weird that the leanest cylinder is also the coolest.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
06 Jul 2010 20:43 #380707
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic #3 cylinder not quite right
It may not be that lean, but perhaps you need a vacuum carb sync, becuase that cylinder is recieving a very small amount of fuel charge, or maybe misfiring not recieving any at all at idle.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- chrispysaki
06 Jul 2010 21:05 #380709
by chrispysaki
A carb sync was going to be my next step, but I found a post in another forum that I think might be the answer — an exhaust leak. That would explain both why the plug was lean (more air flow) and why that pipe was cooler than the rest (exhaust escaping from the head rather than going the usual route). I just tightened the pipes, so we'll see if that does the trick.
- H1Vindicator
- Thank you received: 53
07 Jul 2010 05:56 - 20 Feb 2013 20:29 #380748
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:29 by H1Vindicator.
- chrispysaki
07 Jul 2010 11:42 #380812
by chrispysaki
Sorry, it's an '80 kz750 (4)
- H1Vindicator
07 Jul 2010 12:25 - 20 Feb 2013 20:29 #380816
by H1Vindicator
- chrispysaki
07 Jul 2010 14:57 #380842
by chrispysaki
I actually checked those recently, but it's easy enough to check again. Thanks for the tip.
- mtkawboy
- Thank you received: 16
08 Jul 2010 08:43 - 08 Jul 2010 08:45 #381021
by mtkawboy
Replied by mtkawboy on topic #3 cylinder not quite right
The experiences Ive had would tell me that the pilot jet or channel is partailly plugged. Replace that one or run a guitar string thru it & spray carb cleaner & air down thru the hole & make sure it comes out the carb body. With this crap gas they do that all the time if you let them set for 6 weeks without starting. Ive started running some fuel injection cleaner in the gas tank. Also make sure the air bleed holes in the front of the carb are clean too. Also once you have the plug fouled they will seldom clean out again with the crappy stock coils, replace it.
Last edit: 08 Jul 2010 08:45 by mtkawboy.
