Where to buy cheap carb float boal/top gaskets
- RobQ
06 Jul 2010 12:07 #380598
by RobQ
Replied by RobQ on topic Where to buy cheap carb float boal/top gaskets
shweeeeet.
- bill_wilcox100
- Thank you received: 5
06 Jul 2010 13:21 - 06 Jul 2010 13:24 #380604
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Where to buy cheap carb float boal/top gaskets
otakar wrote:
FYI, here's the gasket set otakar refereed to:
Price sounds hard to beat. If you get one of these sets could you get back to us with the quality level they provide.
Best of success,
Bill
PS,
Could you please add your year, model number and location to your signature to make it easier for members to help you out... and it's considered real friendly too.
Bill
This is where I buy mine.
stores.ebay.com/OC-cycle-parts?_rdc=1
Best of success,
Bill
PS,
Bill
Upgrades:
Montreal, Canada
Last edit: 06 Jul 2010 13:24 by bill_wilcox100.
- dshelly
06 Jul 2010 14:39 #380617
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Where to buy cheap carb float boal/top gaskets
I just like the way he spelled Bowl. Boal? your english teacher should be very proud.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- otakar
06 Jul 2010 14:51 - 06 Jul 2010 14:59 #380621
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Where to buy cheap carb float boal/top gaskets
bill_wilcox100 wrote:
The quality of his gaskets are very good. I have bought carburetor gaskets and engine gaskets from him. But if someone is really good and has what you want it is this guy. His stuff is fantastic and really cheap. His selection and stuff is a bit eclectic, but quality is the best.
cgi6.ebay.com/ws/eBayISAPI.dll?ViewSelle...ame=STRK:MEFSX:MESOI
Unfortunately the KZ550 has those TK carbs and individual gaskets are next to impossible to find. When I posted that link. he did not yet state it was a 81 KZ550.
Best of success,
Bill
PS,
Bill
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Jul 2010 14:59 by otakar.
- XLerate
07 Jul 2010 08:57 #380778
by XLerate
´96 KZ1000-P15, '81 CB750C, ´75 CL360, ´69 SL90, ´69 CT90, ´79 ATC110, ´73 GS550E, ´96 GN125E, ´80 YZ486G, ´72 AT2M Enduro
Replied by XLerate on topic Where to buy cheap carb float boal/top gaskets
Here's a trick for cutting out your own precision gaskets.
Choose the appropriate gasket material and get a piece of cereal box type cardboard and a can of paint that brightly contrasts to gasket material.
Layout gasket material and cardboard side by side, put a good even light coat of paint on cardboard. Take your part to be gasketed and press it lightly against wet paint on cardboard, then press the part down on gasket material sheet.
Works much the same as an old fashioned ink stamp pad, transferring image. In some cases you can actually use an ink stamp pad, if the ink's color will show up; those available at any stationary store.
Exacto knife does the rest! Simple to clean the paint or ink off parts before reassembly. Sometimes helps to trace around the cleaned part with Exacto knife while it's sitting on gasket to get the initial outline, depends on gasket type & material.
