rubber diaphrams are old and cracked
- RobQ
05 Jul 2010 23:04 #380526
by RobQ
rubber diaphrams are old and cracked was created by RobQ
the rubber diaphrams on my float bowls are cracked and need to be replaced. But they are not coming off and are cracking in pieces. Should i boil the bowl in water the loosen teh grommett and scrape away the rest of the rubber???
- RobQ
05 Jul 2010 23:05 #380527
by RobQ
Replied by RobQ on topic rubber diaphrams are old and cracked
- Mcdroid
- Gone Kwackers
- Thank you received: 319
06 Jul 2010 02:45 #380537
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic rubber diaphrams are old and cracked
Just scrape the old gaskets off, being careful not to gouge the float bowl surface. You can use a commercially available gasket remover/softener...or just elbow grease
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
- Thank you received: 337
06 Jul 2010 11:24 - 06 Jul 2010 11:26 #380580
by bountyhunter
Replied by bountyhunter on topic rubber diaphrams are old and cracked
I believe it's OK to soak those bowls in solvent which would loosen the hardened material. You could use naptha, mineral spirits, acetone or even gasoline.
Last edit: 06 Jul 2010 11:26 by bountyhunter.
- Thank you received: 2237
06 Jul 2010 11:34 #380585
by TexasKZ
Replied by TexasKZ on topic rubber diaphrams are old and cracked
When those o-ring gaskets get hard and cracked, toss 'em. Trying to use them in that condition will lead to a great deal of head banging, long sleepless nights, and the use of adult vocabulary.
