Throttle question
- bhardy501
05 Jul 2010 20:30 #380502
by bhardy501
1980 KZ1000B LTD
Throttle question was created by bhardy501
I was out on my KZ1000 this evening and noticed that the throttle has a lot of free turn in it before it catches. It has full throttle range once it catches but it has about 1/4 turn in the throttle before. It hasnt had this. Could something be out of adjustment? If so how do i readjust it? I have it listed on Ebay and need it fixed.
1980 KZ1000B LTD
- PLUMMEN
- Thank you received: 104
05 Jul 2010 20:39 #380507
by PLUMMEN
Replied by PLUMMEN on topic Throttle question
check the cable on the carbs,sounds stretched
- bhardy501
05 Jul 2010 20:47 #380509
by bhardy501
1980 KZ1000B LTD
Replied by bhardy501 on topic Throttle question
Thanks Plummen, if it is stretched can it be adjusted out? If not will the cable from 76 KZ900 fit it to replace it with?
1980 KZ1000B LTD
- PLUMMEN
05 Jul 2010 20:52 #380511
by PLUMMEN
cables from 73z1 through 80mkII should be pretty close i believe,ltd cables might be a little longer
- bhardy501
07 Jul 2010 19:45 #380921
by bhardy501
1980 KZ1000B LTD
New cables are only about $15 each so I ordered 2 new ones to replace both push and pull cables. I was looking through my Clymer manual to see how to change them and I have to say that manual is about useless. It had nothing on changing out my cables. Anyone have a diagram on this or a link to a site that explains it?
1980 KZ1000B LTD
