Fuel line routing question
- KB02
09 Apr 2006 07:22
Okay, so i am starting to work on my '80 550 and am too impaient for the manual to get here (I'm sure the question is answered in there somewhere, but the boook is in the mail).
When I got he bike, the tank was off as were the carbs. I am just trying to figure out where tubes go to hook up the tank. As you can see in the first picture, there are two outlets on the petcock. Outlet #1, I am asuming, is the main fuel line? What is outlet #2 for?
On the inlet picture, it is a shot of the space between #3 & 4 carbs. Inlet #1 I am assuming, again, is for the main fuel line? Inlet #2 is a short t-fitting between Carbs 3 & 4 and has a counter part on carbs 1 & 2. What are these for? Air/overflow vents?
AND, inlet #3. This is the one that confuses me the most. There is only this one on carb #4. I notice that the Petcock has a prime position. Is this for the primer? Does Outlet #2 on the petcock connect to inlet #3 on the carbs?
Post edited by: KB02, at: 2006/04/09 10:29
- KB02
Re: Fuel line routing question
09 Apr 2006 07:28Please Log in or Create an account to join the conversation.
- KB02
09 Apr 2006 07:31
The petcock pic. Sorry. I was having troubles getting this come through on one post.
Post edited by: KB02, at: 2006/04/09 10:32
- Sputnic81
09 Apr 2006 08:04
The larger, (bottom when tank is mounted, #2 in your pic) outlet is the main fuel line. The smaller one (#1) is a vacuum line.
On your carb, I know the one you have marked #1 is the main fuel line. One of the others well go to the vacuum line on the petcock, but I'm not sure which one. Mine is a 440 so it is a little different. I'm sure someone else will post what they got to here very soon.
- Vter Bob
09 Apr 2006 15:31
I'm not really sure but those may be vacuum ports for the emissions control stuff on the 80 550. I will take a look at my bike and get the manual out to see if I can figure it out. You may also want to go to buykawasaki.com and look under "owner information" they have some pretty decent parts diagrams there that may help. Ride safe neighbor!
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
