spits out intake and exhaust. high idle when stop
- hwrecker
the problem I'm having is this. the bike runs wonderfully, but when I come to a stop, the engine works its way up to about 3000 rpms. if I bog it down by letting up the clutch, she will come back down temporarily but then sometimes work it's way back up. it is also backfiring pretty severely whenever I let up off the throttle and it's winding itself down. and sometimes spitting feul out of the #1 carb air filter pod. I don't know anything about this bike. can anyone please help?
- TerryK
- Thank you received: 3
With the bike idling, spray each intake boot with something like wd-40. (not too much, you dont want a fire!) If the idle comes down momentarily you've found your leak.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- hwrecker
- TerryK
thanks! and do you have an idea about the backfiring and feul spitting back through the carb?
Fix the air leak first. It may be causing the backfire problem as well, but it could also be a bad plug in that cylinder, plug wire, coil (less likely), miss ajusted intake valve, bent or sticking intake valve.
Like I said, start with the obvious stuff first!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
start with the boots and new plugs .
I did this just last week and have had great results!!
84 kz 700 a1
82 kz550 ltd
- hwrecker
after running beautifully for a week or two (minus a slight hesitation when you first roll on the throttle and backfiring) I was going down the freeway and it began to surge and lurch. slightly at first, then worse. now it will idle for a while then do something crazy! it had a small explosion come out of the air pods, and smoke came out of them for a little bit.
it is backfiring severely. also popping and i think missing. I have the carbs off now and am thoroughly cleaning them. they don't seem to have a way to adjust them. all four plugs were black and maybe fouled. the guys at auto zone said this is caused by the engine running far too rich. how can I lean it out? there only seems to be one jet! it does have k and N pods on it but they are verrry worn out.
I want to adjust the valves but I don't know what the clearance should be. it is an 81 csr kz 1000 m1.
this bike was my stepfathers. it is very sentimental. I'm a halfway decent mechanic, but i'm stumped. any ideas?
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- hwrecker
- hwrecker
- hwrecker
Attachment Sprintpictures_07102010_0810.zip not found
- otakar
2) the valve adjustment should be at about 5000Mi intervals.
3) it is not an ignition problem.
4) check to see that none of the vacuum lines leading to the top front of the carburetors are leaking.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- hwrecker
there are no vaccum lines to speak of!
there is one line going from carb 1 to carb 3. one line going from the petcock to to carb 2, and I capped carb 4.
I took the carbs apart and cleaned them, but there doesn't seem to be any way to adjust them. there is only one jet. the other place (where I would assume a second jet would be) just has a plug on it.
the bike was running fine. just super rich and backfiring. how can I lean out the feul?? this new lurching/surging problem just happened. I initially thought that a leaky petcock had filled the engine with gas, it felt exactly like when that happened to my suzuki. changed the oil and got no response. It was spitting feul out of the carbs just once in a while, but then they actually ignited and made a puff of smoke.
I replaced all of the spark plugs, which were very blackened, and the problem still persists. should I need new wires? new coils?
