- Thank you received: 1
Installation question for K&L carb rebuild kit
- nicksorg
02 Jul 2010 18:11 - 02 Jul 2010 18:41 #379780
by nicksorg
1982 Kawasaki KZ1000-K2
Installation question for K&L carb rebuild kit was created by nicksorg
Seems like a dumb question, but I'm a little stuck. Bike is a 82 GPz750 with Mikuni BS34s. I ordered 4 carb rebuild kits from Z1. They got here today so I went to install them but have a question. I'm guessing the green arrow is pointing to the pilot jet plug and the red arrow to the o-ring that goes with it. I tried putting the plug in with the o-ring on the end and it doesn't seat well. Seems like the o-ring is too big. I believe the other plug is for the idle mixture screw on top of the carb.
Thanks
Nick
Thanks
Nick
Last edit: 02 Jul 2010 18:41 by nicksorg.
- Motor Head
- Thank you received: 391
02 Jul 2010 18:23 #379783
by Motor Head
Replied by Motor Head on topic Installation question for K&L carb rebuild kit
No it is for the Pilot jet, it plugs the area where the jet screws in. Forcing the pilot jet to pick up fuel from the main jet well.
- nicksorg
02 Jul 2010 19:17 #379787
by nicksorg
Replied by nicksorg on topic Installation question for K&L carb rebuild kit
It turns out I have one of the old pilot jet plugs I pulled out before I cleaned the carbs. It's similar in size to the plug I pointed out. It seems like I need a really small o-ring to go on it that's not in the kit.
- nicksorg
12 Jul 2010 01:40 #381900
by nicksorg
I bought 4 of the smallest metric o-rings that my local Napa had. These worked great and I was able to seat the plugs in the pilot jet holes.
Nick
Nick
- PLUMMEN
- Thank you received: 104
12 Jul 2010 05:15 #381911
by PLUMMEN
Replied by PLUMMEN on topic Installation question for K&L carb rebuild kit
personally the only part ive ever needed to replace in a set of carbs unless they were completely trashed was the gaskets or an occasional float which never comes with kit anyway.
putting chap stick on both sides of bowl and top gaskets helps keep them from sticking so they can be reused in my experiance anyway
