Who has the best prices on carb kits?
- kz.chris
01 Jul 2010 19:14 #379557
by kz.chris
1977 Kawasaki KZ650
Who has the best prices on carb kits? was created by kz.chris
The best I've found so far is $21.95 for one carb at oldbikebarn.com
www.oldbikebarn.com/Kawasaki-KZ650-KZ750-Carb-Kit
Anyone know of a better place?
1977 Kawasaki KZ650
- Beard
01 Jul 2010 19:19 - 01 Jul 2010 19:19 #379558
by Beard
79 KZ650B
Jack of everything, Master of nothing.
Replied by Beard on topic Who has the best prices on carb kits?
$20 x 4 = 80 + shipping
will you have to do it all again later down the road?
will you messing with points adjustment as they wear?
or go dyna electronic ignition
www.z1enterprises.com/detail.aspx?ID=201
79 KZ650B
Last edit: 01 Jul 2010 19:19 by Beard.
- otakar
01 Jul 2010 19:26 #379560
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Who has the best prices on carb kits?
Z1Enterprises has the lowest prices I have been able to find.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
- Thank you received: 540
01 Jul 2010 19:33 #379561
by MFolks
Replied by MFolks on topic Who has the best prices on carb kits?
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.sportingforless.com/servlet/the-Carb-repair-kit/Categories
www.cycleorings.com/
www.carbparts.com
www.jetsrus.com
- bountyhunter
- Thank you received: 337
01 Jul 2010 22:06 - 01 Jul 2010 22:11 #379586
by bountyhunter
Replied by bountyhunter on topic Who has the best prices on carb kits?
kz.chris wrote:
Z1 Enterprises usually has the best prices. I got my Keyster kits from loudfastugly.com for maybe $17/each a while back. They still show them as available.The best I've found so far is $21.95 for one carb at oldbikebarn.com
Last edit: 01 Jul 2010 22:11 by bountyhunter.
- JMKZHI
- Thank you received: 48
01 Jul 2010 22:59 - 01 Jul 2010 23:02 #379591
by JMKZHI
Replied by JMKZHI on topic Who has the best prices on carb kits?
Something you could try is to price the parts separately - the stuff you actually need & will use. I acquired the following, mostly from Z1Enterprises: float bowl gaskets & top gaskets, choke plunger caps & choke plunger o-rings, and a metric nitrile o-ring kit from HarborFreight. The o-ring kit had several sizes that were close enough for the application - the ones for the drain screws, main-jet/bleeder-pipe & pump nozzles. My carburetors were in fairly good condition & didn't need any jets or needles. Maybe your situation is different... just a suggestion.
Also, CycleOrings.com may sell o-ring kits specific to your bike. The website is kinda plain-jane & bare-bones, but I'm fairly certain he's legitimate. I found out about him over at TheGSResources Suzuki forum.
Last edit: 01 Jul 2010 23:02 by JMKZHI.
- kz.chris
01 Jul 2010 23:19 #379592
by kz.chris
1977 Kawasaki KZ650
Replied by kz.chris on topic Who has the best prices on carb kits?
Thanks for the responses. I won a full carb assembly off ebay for $35 include the shipping.
Looks like I will be spending more on the rebuild kits! hahahah :silly:
Thanks again.
Thanks again.
1977 Kawasaki KZ650
