Proper jetting for a 77KZ1000 with pods and a pipe
- frankenbike
01 Jul 2010 13:38 #379476
by frankenbike
Proper jetting for a 77KZ1000 with pods and a pipe was created by frankenbike
I have a 77 KZ1000 and am cleaning the carbs now due to setting around for years. (anyone know where to get some good carb cleaning brushes and wires?) I am adding pod style air filters and a Supertrap header. I live in Champaign Illinois so I'm just a little above sea level. What jet sizes should I use in the stock carbs? Any good info is greatly appreciated.
- Old Man Rock
- Thank you received: 225
01 Jul 2010 14:21 - 01 Jul 2010 14:22 #379484
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Proper jetting for a 77KZ1000 with pods and a pipe
OEM Stock jetting can be found in the attached image....
As for what will be required in jetting.... will also depend on your baffle selection... PM Sax for he lives in Chicago and may be able to get you close for what he found in his jetting...
Keep in mind, his settings will be different then yours due to higher non stock pistons, cams, valve sizing and head porting in his KZ....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 01 Jul 2010 14:22 by Old Man Rock.
