* ltd 1000j carbs
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
30 Jun 2010 13:26 #379249 by Dickey Durango
* ltd 1000j carbs was created by Dickey Durango
Hi I'm a newbie and my name is Randy. I am not sure which carbs I have But I'm pretty sure they are cv because of the pull out choke and square tops.I've heard alot of bad things about them. They are pretty gummed up from sitting since 97. Should I clean and re-jet these or should I spend my cash on better carbs? I also will be going with pods and was told they don't work the greatest with these.::S
82 Kz 1000 LTD
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
30 Jun 2010 13:27 #379250 by Dickey Durango
Replied by Dickey Durango on topic * ltd 1000j carbs
I'm sorry since 07 but anyway
82 Kz 1000 LTD
  • 9am53
  • homebrew, and some bbq
30 Jun 2010 14:03 #379259 by 9am53
Replied by 9am53 on topic * ltd 1000j carbs
I suppose that regular manual slide carbs are easier to tune with pods...but I have the same bike as you and put pods on this winter. Although I am a newbie I have had and am having no issues with these carbs, many people put pods on them. Some people hate them with a passion for some reason, some people love them. I figure the carbs are just fine and you will be ok.
30 Jun 2010 14:05 - 30 Jun 2010 14:08 #379261 by otakar
Replied by otakar on topic * ltd 1000j carbs
Mikuni BS34ss CV carburetors. I think that they are great. I have a set on my GPz1150 and I love them. I would have no other carburetor. Including smooth bores. Wit a little work they can be as good as a set of 31mm smoothbores. If you have any questions you can PM me.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 30 Jun 2010 14:08 by otakar.
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
30 Jun 2010 14:13 #379262 by Dickey Durango
Thanks for your replies. I guess I'll just buy a hanfull of jets and figure out what works.I would just keep the stock airbox but what a pain
82 Kz 1000 LTD
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
30 Jun 2010 14:14 #379264 by Dickey Durango
Sweet lookin gpz by the way
82 Kz 1000 LTD
  • hocbj23
  • Visitor
30 Jun 2010 14:22 #379265 by hocbj23
Replied by hocbj23 on topic * ltd 1000j carbs
I have the BS 34s on my bike (82 CSR) and other than a good cleaning,replacing the float gaskets, seats and needles and using a K and N filter in the stock airbox,mine runs fine.U could do a lot worse and sometimes the more u fiddle,the worse the bike runs.Ask me how I know.Lol.bj
  • Motor Head
30 Jun 2010 16:20 #379290 by Motor Head
Replied by Motor Head on topic * ltd 1000j carbs
Get some rebuild kits, they will have the new jets, stock bike? Stock jets in the kit will be good, unless you a Mile high like me. Then Leaner is good.
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
30 Jun 2010 21:38 #379395 by Dickey Durango
It just has a 4-1 header not sure the make because there's no markings visible.It also needs an ignition switch if anyone knows who has one. It was a friend of mines,and he passed away. I ended up with the bike but his daughter gave me the wrong key.only 10,000 miles
82 Kz 1000 LTD
01 Jul 2010 03:34 #379420 by otakar
She started out life as a 81 CSR 1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Dickey Durango
  • Topic Author
  • 82 KZ 1000 ltd
01 Jul 2010 06:36 #379431 by Dickey Durango
Yeah I was checkin out your project, that's amazing work you did!I may do something similar to my LTD in the future.For now I just need to ride. I'm laid off so cash is tight. Do you have the Ignition switch off the CSR or did you use it?
82 Kz 1000 LTD
01 Jul 2010 06:59 - 01 Jul 2010 07:06 #379435 by otakar
I'm using the stock key ignition from the CSR with a custom cluster modified from a ZN1100 cluster. I still have the CSR instrument cluster. I installed a cigarette liter plug for my electricity heated gloves and GPS adapter. The handle bars are a set of "superbike Bars" by "Bikemaster" and I installed an after-market master cylinder. I also have an after market "K&N" left control which I will be installing this weekend. The trippletree is stock CSR but the forks are GPz. I now got a set of Police forks which I am rebuilding for it. The mirrors are also aftermarket eBay and are MUCH MUCH better than the stock mirrors. They have a much better field of view. With the stock mirrors I couldn't see behind me at all. These give me a full field of view, I love them. The light is a stock GPz bucket with a custom reflector and a HID system installed. I have an osculating LED driving light mounted under the fairing.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Jul 2010 07:06 by otakar.
