- Thank you received: 7
mikuni rs34 tuning
- jumbulias
27 Jun 2010 02:16 #378492
by jumbulias
mikuni rs34 tuning was created by jumbulias
I am needing some help tuning a set of mikuni rs34 carburetors on a 78 kz1000 ltd. The only mods are Denco 4 into 1 header, Kn pods, Dyna S ignition, Dyna Coils.The pilot jets are 115, mains are 130 and the needles are still set where they were when purchased. Right now it seems to hesitate when you first hit the throttle. Mid range and top end is pretty smooth. I do not know much about tuning carbs so any help would be appreciated. Thanks Jumbulias
- Old Man Rock
- Thank you received: 225
27 Jun 2010 05:19 #378499
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic mikuni rs34 tuning
Follow the link for the RS tuning manual...
kzrider.com/index.php?option=com_docman&...d&gid=481&Itemid=108
The manual is actually for the HS series but is used for the RS series as well.... Pretty much all I could find on the web for tuning Mikuni RS series carbs....
As depicted on the first page, for idle and low rpm ranges pilot system.... from 1/16th to 1/4 throttle, Needle jet & jet needle... Possibly the accelerator pump... See image below red boxed text...
Then there's the consideration where may just be due to the issues of too large a carb for a stock 1000 engine without any head porting, performance cams and such, they will stumble at low rpm's....
Use the search function and you'll find postings on it...
Good luck,
OMR
Good luck,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- beefsquasher
27 Jun 2010 14:29 #378604
by beefsquasher
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
Replied by beefsquasher on topic mikuni rs34 tuning
I have (or had, at least) a very similar engine combo as you, and my RS34s acted exactly the same way. Work fine from 4-5k on up, but smack the throttle open below that and you get a big bog and THEN it goes.
3 things:
-Bench sync your carbs. Don't even bother using vacuum gauges on these - the slides rattling back and forth and sucking air from the top cover as you adjust them will drive you nuts and you'll have a crappy running engine to boot. Take the whole rack off you bike. Go to the hardware store and get 4 NEW ball bearings about 1/8" to 1/4" in diameter. Pop off the tops of the carbs and adjust 1 carb a a time, referencing it to the master carb by slowly screwing the idle adjuster in and making the ball bearings fall through at the same time as the slides are lifted. Get it PERFECT, lock it down, and never touch it again.
-Adjust your accelerator pump to maximum. Have it start squirting as soon as you crack the throttle open, and adjust it so it uses as much of the stroke as you can, this will keep it squirting almost all the way up to 3/4 throttle. I have never had any problems with too much fuel. These bikes love gas when you are snapping the throttle open, so provide it!
-Check your valve clearances, and make sure they are all spot on. You'll be suprised at the difference it makes.
Doing these three things helped a whole lot with my bike. It still gets mad if you really try to pour on the gas at like 2500, but remember, these carbs are significantly larger than these ones originally on the bike, and they are a top-end / bottom-end compromise until you really get some flow with either a big bore kit, higher compression, or some careful port work.
-Dave
3 things:
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- TerryK
- Thank you received: 3
27 Jun 2010 15:01 #378609
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic mikuni rs34 tuning
Dave pretty much nailed it.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
