- Thank you received: 1
kz750 carb identification
- tw..
08 Apr 2006 09:46 #37822
by tw..
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
kz750 carb identification was created by tw..
i'm trying to identify a set of kz750 carbs i have. i know the carbs came off a 1980 kz750 twin. i was told that there are numbers on the carb bodies but i dont see any. does anyone here know exactly where i should look for this number?
2-1976 KZ900 A4
1978 Z1R
- mykykz
03 Feb 2007 22:19 #110052
by mykykz
Replied by mykykz on topic kz750 carb identification
The numbers should be on the right side of the carbs. They are stamped on the flange near where they mount to the intake. Probably 3 numbers over 2. For example:
450
20
You should be able to seen them from above carbs. And if yours are like mine, you'll probably have to keep a cleaning brush handy to clean the surface in order to read the number. Hope this helps
450
20
