Rubber fuel line T-fitting question
- Maxwedge
08 Apr 2006 08:15
I am rebuilding the carbs on my 1980 kz650. The previous owner partially dissasembled them before I bought the bike and it looks like he damaged one of the fittings that go between the carbs where the fuel line attaches to. The thing is a black, T-shaped rubber coated tube with 2 sort of integrated o-ring deals on each end, one of which is chewed up pretty bad. Dealer wants $65 for a new one and said it may take 2 weeks to get it. Anybody know of a good way to fix this. Some type of sealer? Can I replace it with brass fittings of some sort? Is it possible to replace the o rings on this thing? Looks like it's all one peice, but may be just really gummed up?
Thanks
Thanks
- kz1000g
Re: Rubber fuel line T-fitting question
08 Apr 2006 19:14
I have been told that you can use liquid electricial tape, but I have never tried it.
I just bought 2 of the T's from Z1 Enterprises last week $14.82 each www.z1enterprises.com
Paul Sr.
kz1000g
Paul Sr.
kz1000g
- dan76kz900
08 Apr 2006 19:41
Mine werent chewed up, but they leaked after I put my carbs back together after the rebuild. I ended up wrapping alot of teflon tape around the ends and it worked
For $14.82 each.. I'd say thats worth the price for peace of mind. When I was looking for them, I couldnt find them for that cheap ! I'm gonna look and see if their avalaibe for my bike.
- dan76kz900
08 Apr 2006 20:24
- arobsum
08 Apr 2006 20:43
my 2 were almost bare..no rubber left...
i used fuel safe sealant and smeared it
over each end and jammed them together..
its kinda permanent but it worked..no leaks.
