Low vacuum in right carb and wet plug
- chrispysaki
24 Jun 2010 07:31 #377914
by chrispysaki
Low vacuum in right carb and wet plug was created by chrispysaki
When I put my hand over the right carb inlet there is very little vacuum pressure pulling my hand toward the carb, and I noticed that plug looks wet/glossy.
On the left hand side, the plug looks normal and the vacuum pressure pulls my hand straight against the inlet.
Is this a carb problem? compression problem? valve problem? something else entirely?
thanks,
Chris
thanks,
Chris
- Motor Head
- Thank you received: 391
24 Jun 2010 07:37 #377915
by Motor Head
Replied by Motor Head on topic Low vacuum in right carb and wet plug
Start with a compression test, wet plug means it is not burning the fuel entering the cylinder. Compression, fuel spark, these are all needed.
Have you a gauge for this? Have you done a valve adjustment?
Also check you spark, coil, etc.
If the compression, spark, are oK. Then its pull the carbs and go through them, you may have a high fuel level do to a bad float, or the needle and seat for the fuel level.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
28 Jun 2010 16:17 #378813
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Low vacuum in right carb and wet plug
Whens the last time you had a good manometer syncronization/testing done?
It is required maintenence.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
