bike will not start
- lgj069
- bountyhunter
- Thank you received: 337
1) check compression
2) check static timing
3) check spark plugs against the cylinder to observe good spark
4) check plugs to see if they are wet (getting gas)
This part:
definitely sounds carb related like a vacuum leak or a plugged jet.would only run if I kept the RPMs up over 2000
- lgj069
- jeffasaki
- Thank you received: 44
Good Luck
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2098
Failure to idle down may also result from imperfect carb pilot circuits. If turning pilot adjustment screws doesn't produce rpm change, there's likely something wrong in the pilot circuit (typically inadequate cleaning), especially where ignition (spark and timing and advancer function) and compression (including valve clearances) are okay.
- Dragone
Did you pull in the clutch? The 77 650 has a clutch lockout switch that will not let it start unless the cluch is pulled. Unless you are kicking it then it does not matter
The 92 1k is that way as well.
but as mentioned, generally it is a carb adjustment issue. Then, the also mentioned mechanical checks. good luck and enjoy the training.
- lgj069
Thank you all so much!!!!!
- KZ250LTD
- Thank you received: 16
Generally, there is just enough fuel left in the lines to get you halfway through an intersection when you forget to turn it on after filling up :laugh:
79 KZ1000ST
Past:
Many.
