red hot exhaust
- Tuco
21 Jun 2010 18:25 #377393
by Tuco
red hot exhaust was created by Tuco
Just acquired a 79 kz 750- got it running after new fuel
and plugs but it's still faltering and one of the exhaust
pipes gets red hot (very visible at nite). Could it be running lean from a bad carb or is it more likely a valve
problem?
problem?
- PLUMMEN
- Thank you received: 104
21 Jun 2010 18:39 #377399
by PLUMMEN
Replied by PLUMMEN on topic red hot exhaust
check carbs/filter
- Thank you received: 2098
21 Jun 2010 19:59 - 21 Jun 2010 20:04 #377435
by Patton
Replied by Patton on topic red hot exhaust
Would also check ignition timing, and that advancer unit is correctly functioning.
When setting timing, always use the F marks. Ignore the T marks.
See example pictured below.
[Click on image to enhance view.]
Last edit: 21 Jun 2010 20:04 by Patton.
- loudhvx
- Thank you received: 1616
22 Jun 2010 09:17 #377530
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic red hot exhaust
Wow, that is a big difference in advance curves between the early and later Z1. What changed, the idle-position or the full-advance position?
1981 KZ550 D1 gpz.
Other links.
