Bog at 4 - 6k in any gear....
- Kingchiefa
- To each thier own.
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- bountyhunter
- Thank you received: 337
- Kingchiefa
- anarki650
09 Kawasaki ER6n
Omaha NE
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
My bike bogs down when reaching 4K rpm and continues through 6K. What would cause this and how do I fix it?
While riding, could add a little choke during the bog to determine whether performance improves, or worsens, or stays the same.
May aid diagnosis.
- Old Man Rock
Bogs or falls flat on it's face?
Falls flat then too lean...
A method Larry taught me is during a ride, rev it up to 5/6 grand and hold it steady in 5th gear, does she run smooth smooth or sputter/oscillates as if running out of gas/clogged fuel line "henceforth fall flat on face" etc...?
Also, same scenario, let go of the throttle, let her snap shut, does she back fire, pop out the exhaust?
If either of the above holds true, too lean change to a richer clip position if optional on your setup or richer needle.
As Patton mentioned, pull the choke on a tad, she runs better then yup, too lean...
Plug conditions would also provide you some insight to running conditions...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Kingchiefa
Carbs in sync?
Yeah carbs are sync'd perfectly.
- Kingchiefa
Would raise the needle a step and see if that fixes your woes.
Why would you raise the needle a step? Wouldn't that create a richer mixture?
- Kingchiefa
A bog in this range would usually indicate too lean on the needles. A stutter would indicate too rich in the needles.
it is a stutter not a bog... My bad guys.
