can floats go bad?
21 Jun 2010 15:18 #377329 by asevans
can floats go bad? was created by asevans
recently set my fuel levels in my carbs. 26's. i then decided to take them off and clean them more thoroughly. i noticed that when upside down with the bowls off my floats they are way different to one another. elevation. also after i reinstalled and test rode it with the fuel valve still on a lot of gas was flowing out of the overflows. the needle valves and seats are about one year old. im wondering if the buoyancy has gone out of the floats and not sealing my needles and causing the floats to be at different elevations. also if so where can you get new ones at? i didnt see any at Z1.
thanx
1976 kz900 Mostly stock
1978 Z1-R Project
21 Jun 2010 16:06 #377339 by Dragone
Replied by Dragone on topic can floats go bad?
did the floats have fuel in them? I have seen cracks and pin holes in a float that will of course cause overflowing
21 Jun 2010 16:44 #377350 by polkat
Replied by polkat on topic can floats go bad?
Yes, they can go bad. I've seen holes in both plastic and brass floats. Usually found around where the hinge connects to the float, and is often found in older floats that have been bent for adjustment a number of times. Causes the float to fill with gas and then it just sits at the bottom of the bowl.
As Dragone mentioned, the best way to tell is to shake the float near your ear in a quiet place. If there's gas in it, you hear it sloshing around, or if you move it around gas will seep out. The best repair is to replace, but some can be fixed if you are good with a soldering iron or glue. Never try to solder a float if it isn't completely dry of gas!!
21 Jun 2010 17:05 #377357 by Dragone
I like polkats explaination better. lol
21 Jun 2010 17:26 #377364 by PLUMMEN
Replied by PLUMMEN on topic can floats go bad?
yes you can either hold them to your ear and shake them to see if you can hear the ocean or you can have them checked by the coast gaurd,remember what happened to the barges in louisiana for having improper floats! :S :woohoo:
on a side note:i once held my ear up to a girl on the beach in california,i couldnt hear the ocen at all over her screaming! :blink: :woohoo:
21 Jun 2010 17:47 #377372 by bhardy501
Replied by bhardy501 on topic can floats go bad?
One of the floats on my KZ1000 would fill up with gas and laet it over flow. I emptied it twice and it took about a week for it to fill back up and let the needle valve stay open. I replaced it and no more problem.
1980 KZ1000B LTD
21 Jun 2010 19:10 #377414 by Patton
Replied by Patton on topic can floats go bad?
Floats may be okay and just need tang adjustments to set correct fuel levels inside float bowls.
The clear tube test is the most reliable method to set the float heights toward achieving the correct fuel level.
Forget the upside down dry measuring technique, as it's notoriously inaccurate.
Good Fortune! :)
[Click on image to enhance view.]
21 Jun 2010 19:13 #377417 by Patton
21 Jun 2010 19:50 #377426 by Patton
21 Jun 2010 19:50 #377428 by Patton
21 Jun 2010 19:51 #377429 by Patton
21 Jun 2010 19:55 #377432 by Patton
Type Clear Tube Test in the Search Forum box.
Then click on Go.
Good Fortune! :)
[/quote]
