Adjusting idle
- Lazyman06
Adjusting idle
20 Jun 2010 11:13
How does on adjust idle on a '79 KZ1000? I'm used to a thumbwheel style adjuster but can't seem to find one.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- TeK9iNe
- What did you do!?!
Re: Adjusting idle
20 Jun 2010 11:18
On your model I believe there is a thumbwheel, just that it is located behind, and atop the carb rack in the middle.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Lazyman06
Re: Adjusting idle
20 Jun 2010 11:46
did they make it hard enough to get to? lol
- Lazyman06
Re: Adjusting idle
30 Jun 2010 15:37
well I looked for it and only thing I can think of is it's part of the throttle cable. also I found a lever on the bottom side of the carbs that's has a spring to return it to the regular position. Any idea what this is?
- bill_wilcox100
Re: Adjusting idle
30 Jun 2010 16:26 - 30 Jun 2010 16:27
This is the diagram for a 1978 KZ1000 A3/A3A as found on Kawasaki.com. See item 23. Find this and you have found your idle adjustment.
Best of success,
Bill
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 30 Jun 2010 16:27 by bill_wilcox100.
Re: Adjusting idle
30 Jun 2010 16:29
Thumb screw for idle adjustment is found between middle pair of overflow tubes where they attach to the float bowl nipples.
