- Thank you received: 225
Petcock Problemo!!
- Old Man Rock
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- loudhvx
- Thank you received: 1616
His bike works fine if the tank is in the prime position.Maybe I missed it but what about the tank cap itself venting...checked/confirmed operating correctly?
Just a thought...
OMR
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- rsrcafe
- loudhvx
The Syringe should go back even in prime?
Yes, as long as you are attaching the syringe to the vacuum port on the petcock. There should never be any airflow through the vacuum port on the petcock. If it did, then the bike would have a vacuum leak on the #4 cylinder (or which ever cylinder the vacuum petcock is connected to). Regardless of petcock position, there should be no air through the vacuum port. If there is, then something is not sealed properly.
1981 KZ550 D1 gpz.
Other links.
- rsrcafe
The tech and I figured a dab of super glue on the male end of the daiphragm would hold the seal to it and would pull it open even if it got a little sticky from the gas/ethanol.
Go Figure...
Thanks for all your valuble input.
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- wannaby
- cobura
- forever 2 wheels
1979 KZ650B3
- loudhvx
In other bikes I've seen the port on one fo the actual intake manifolds.
So it can be in one of several places, but you'll need someone who knows specifically on your bike.
1981 KZ550 D1 gpz.
Other links.
- cobura
- forever 2 wheels
1979 KZ650B3
- Thank you received: 2237
- hocbj23
- Visitor
