- Thank you received: 16
82 GPZ750 carb problem
- mtkawboy
19 Jun 2010 08:02 #376775
by mtkawboy
82 GPZ750 carb problem was created by mtkawboy
Bike starts & idles fine but when you go to rev it up it dies after reving to about 3000. I checked fuel flow thru petcock, took carbs off checked diaphragms by holding finger over hole & slides dont drop, took carbs apart, checked float levels & cleaned carbs, put them back on & bike does the same thing,checked for vacuum leaks & there are none, manifolds are good. Ive built a bunch of these carbs & cant find a problem, Any help would be appreciated. These are 34mm Mikuni Cv carbs. Bike ran fine last time I rode it. Im stumped !
- hocbj23
- Visitor
19 Jun 2010 12:26 #376816
by hocbj23
Replied by hocbj23 on topic 82 GPZ750 carb problem
advancer on ignition working properly?bj
- mtkawboy
20 Jun 2010 17:16 #377106
by mtkawboy
Replied by mtkawboy on topic 82 GPZ750 carb problem
Its not the advancer It was working but I lubed it up & it still does the same thing. Starting to think I have a diaphragm problem. Ill pull the carbs again & check it out. God,I love these factory air boxes !
- Motor Head
- Thank you received: 391
20 Jun 2010 18:31 #377127
by Motor Head
Replied by Motor Head on topic 82 GPZ750 carb problem
I just pulled and re cleaned 2 of the things today, those airbox connectors really suck, but the airbox gives the needed signal so the CV slides work right.
Now when checking this out have you made sure that its not losing spark? With a inductive light hooked up? Maybe you have a low voltage causing missfire/ weak spark?
If you have been through the carbs and know how then unless you have missed some thing, I would check the electrical. Maybe you still have a fuel supply issue, have you tried to see the fuel running out of the bowl drains with petcock on "Prime"?
- Thank you received: 2098
20 Jun 2010 23:51 - 20 Jun 2010 23:51 #377206
by Patton
Replied by Patton on topic 82 GPZ750 carb problem
Last edit: 20 Jun 2010 23:51 by Patton.
- mtkawboy
21 Jun 2010 08:54 #377260
by mtkawboy
Air box boots are fairly new & soft. I checked fuel flow on prime and its good. I even tried it with my portable snow blower tank that I use to sync the carbs with. It feels exactly like the slides arent lifting. When you rev it up it stutters amd dies. The battery is a year old but starts it fine. I lifted the slides and covered the hole in the front of the carbs with my finger & they didnt drop. Im taking the damn things off again, something is wrong some where. Thanks for the help guys, keep it coming. Ill try anything at this point. The thing starts & idles fine
- mtkawboy
30 Jun 2010 10:12 #379218
by mtkawboy
Took carbs off again and went completely thru them cleaning & checking everything. Put it back together & it runs perfect except I have no clue what I did to fix it. I can live with that though.
- hocbj23
- Visitor
30 Jun 2010 14:29 #379267
by hocbj23
Well as ole Grandpappa Johnston said:"even a blind hog finds an acorn now and then." Lol. I think we have ALL been there.bj
- Motor Head
30 Jun 2010 16:35 #379297
by Motor Head
I got a Buddy with a GS850, he had someone working on it and spent $800. Would not run above Idle, took me a couple of tries to straight it out. Found out on these Suzi BS carbs, there is a spring that goes in before the needle goes in the slides, these guys had it holding the needle down. It was Super Lean, wouldn't go 10mph. Needless to say thanks for the internet parts diagrams as one look and the "LIGHT" turned on.
He was told he needed a new motor, he's the 1st owner and 18,000mi. They had charged him for carb rebuild, Mix screws were seized in place, floats all out, and no new parts. Broken intake manifolds, wasted air box boots, etc.
Runs great now.
Runs great now.
