JB Weld Failure
- peachc
JB Weld Failure
07 Apr 2006 16:47
Well, I had posted awhile back about a way to fix the float bowl overflow spout broke off and I had used JB weld to fix it, but it doesn't seem to last forever. I just went to start the bike and the fourth carb was continuously overflowing. So my question now is, what coud be used instead of JB Weld which would hold up to constant gas exposure? So any advice would be awesome!
- Duck
- e vica na i sau na ga
Re: JB Weld Failure
07 Apr 2006 18:23
Does anyone know what the carb bodies are made of? Would help in figuring out how to repair.
- JR
Re: JB Weld Failure
07 Apr 2006 18:26
I've used JB Weld before without problem but you do have to leave it about 24 hours to set first. An alternative approach would be to get a bit of thin brass tubing at a Hobby store .......just wide enough to slip over the existing overflow tube.....and solder it at the bottom. I've done this also.
Good Luck
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
Good Luck
Woodstock ON Canada
- peachc
Re: JB Weld Failure
07 Apr 2006 18:32
I am not too sure what the carb bodies are made out of. I don't remember also if I let it sit for 24 hours also, so that might be another problem that I may have had. Did you use the putty kind which you just mixed with your fingers or did you get the kit with the two tubes which you mixed together?
- wireman
Re: JB Weld Failure
07 Apr 2006 18:39
how about some dev-con epoxy.i think the bowls are die-cast from aluminum
- arobsum
Re: JB Weld Failure
07 Apr 2006 19:25
i used jb weld to fix my yamaha carbs. worked great.. be sure to clean the area really good and let it sit for a day or so...should be fine.
- rede4u
Re: JB Weld Failure
07 Apr 2006 20:09
The die castings are probably not Aluminum but Zinc. Zinc is used for automotive parts especially where you have a lot of small details.
Good Luck.
Good Luck.
- wireman
Re: JB Weld Failure
07 Apr 2006 20:27
i was thinking about zinc,but didnt sound right for some reason but i think thats what the stock bodies are made of ,i think aftermarket carbs are aluminum bodies theyre quite a bit lighter.
- bearnekkid
Re: JB Weld Failure
07 Apr 2006 20:47
are u sure they arent magnesium like the deck of a lawn mower its very gas resistant and stable
- wireman
Re: JB Weld Failure
07 Apr 2006 21:23
ive seen magnesium dirtbike cases before but the stock kz carbs are really heavy,thats the same stuff carbs on most carbs are made of die cast zinc.
- Duck
Re: JB Weld Failure
08 Apr 2006 02:38
I HAVE NOT TRIED THIS!
But, hear that the Harris #52 flux with #52 solder is good for zinc casting repais.
If anyone wants to buy me some, I'll be happy to have a go at repairing their cast zinc part...
Duck
Post edited by: Duck, at: 2006/04/08 05:50
Duck
- wolfencopter
Re: JB Weld Failure
08 Apr 2006 06:35
How about grabbing a set of carbs of ebay... You'll have loads of spare parts...then you won't have to deal with trying to repair the broken spout, you can toss it in the trash.
