clear tube fuel test question
- asevans
17 Jun 2010 17:49 - 17 Jun 2010 17:51 #376436
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
clear tube fuel test question was created by asevans
kz 900 stock 26mm carbs. doing the clear tube test this evening and in the manual it says the fuel level should be 1/8 inch below the top of the float bowl. now, the top of my float bowl which is the bottom bowl goes up inside of the top carb body about an 1/8 inch. the picture on the clymers isnt very clear. where exactly do i measure from? thanx in advance.
1978 Z1-R Project
Last edit: 17 Jun 2010 17:51 by asevans.
- beachbum
17 Jun 2010 17:59 #376442
by beachbum
beachBUM
-1978 kz1000
-1979 kz1000
Replied by beachbum on topic clear tube fuel test question
Newb question: What is the clear tube test?
beachBUM
-1978 kz1000
-1979 kz1000
- Thank you received: 2098
17 Jun 2010 18:00 #376443
by Patton
- asevans
17 Jun 2010 18:09 #376447
by asevans
1978 Z1-R Project
Replied by asevans on topic clear tube fuel test question
thanx again.
1978 Z1-R Project
17 Jun 2010 18:15 #376450
by Patton
- asevans
17 Jun 2010 18:17 #376452
by asevans
1978 Z1-R Project
im having trouble with my bike running lean or rich. i thought i would rule out the fuel level being the culprit. what you do is screw a clear tube into the drain plug and open the fuel valve letting fuel to seek its own level. hold the tube up to carb body. the fuel should be where the red line in pattons picture shows. it seems to be pretty important, everybodies always talking about it.
1978 Z1-R Project
17 Jun 2010 18:18 #376454
by Patton
Replied by Patton on topic clear tube fuel test question
- asevans
17 Jun 2010 18:18 #376455
by asevans
1978 Z1-R Project
patton, your on it man
1978 Z1-R Project
- Bluemeanie
- Thank you received: 14
18 Jun 2010 06:00 #376557
by Bluemeanie
Replied by Bluemeanie on topic clear tube fuel test question
Don't know if he's still selling these on ebay, but for $11 it is a great tool! Got mine awhile ago and it works awesome.
Another "level" pic for you!
