- Thank you received: 5
VM26 dripping overflow tubes.
- dshelly
17 Jun 2010 10:46 #376338
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
VM26 dripping overflow tubes. was created by dshelly
Today I was setting the floats on a set of VM26 carbs. (clear tube method) When I noticed that the overflow tubes kept dripping. Even though the float level was OK. Come to find out all four overflow tubes are cracked below the fuel level. What can cause this? and , can thes tubes be replaced or do I need a new set of bowls? If I need Bowls, does anyone have a good set for sale?
Thanks, dshelly
Thanks, dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Thank you received: 2098
17 Jun 2010 13:02 #376362
by Patton
Replied by Patton on topic VM26 dripping overflow tubes.
