GPz305 won't take any throttle
- mjg15
13 Jun 2010 14:22 #375489
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
GPz305 won't take any throttle was created by mjg15
The bike will idle perfectly @ 1500rpm all day long, but wont take any throttle.
I've checked:
-Carbs are clean (ultrasonic)
-Diaphrams appear to be good
-Valve adj. in range
-Compression 150 psi
-Intake manifolds not leaking
-Stock exhaust and airbox
Carbs are Keihin CV32's. Maybe these carbs are supposed to have those plugs near the main/pilot area ?
I've checked:
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Capt America
- Born Bad
- Thank you received: 1
15 Jun 2010 10:12 #375872
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic GPz305 won't take any throttle
mjg15 wrote:
I don't know jack about the 305, but I assume it probably has a mechanical Timing Advancer... I've seen it cause this very problem in a couple of instances. They like to cease up after sitting a while.
Might be worth a look see if you haven't already and just didn't list it.
I've checked:
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- Dragone
15 Jun 2010 16:40 #375947
by Dragone
Replied by Dragone on topic GPz305 won't take any throttle
If you are referring to the two vacuum ports for synchronising, then you will need to plug them.
- mjg15
16 Jun 2010 10:25 #376090
by mjg15
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Replied by mjg15 on topic GPz305 won't take any throttle
Thanks guys.
I'll look into what type of advancer, it's a possibility as the starter was a little sticky. It was stored in a semi dry garage for the last couple years.
I have the sync plugs, I was referring to the ones inside the floatbowl that some carbs have. These carbs dont require them
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
