81 KZ1000 csr
- theGUNSLINGER
12 Jun 2010 14:54 #375295
by theGUNSLINGER
81 KZ1000 csr was created by theGUNSLINGER
Im currently getting my carbs cleaned how will the performance be with stock carbs and 4 pods instead of the airbox i hear it will be bad with pods, is this true
Thanks Rob
Thanks Rob
- otakar
12 Jun 2010 14:57 #375296
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 81 KZ1000 csr
Please explain "having my carbs cleaned" in more detail.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- theGUNSLINGER
12 Jun 2010 15:21 #375310
by theGUNSLINGER
Replied by theGUNSLINGER on topic 81 KZ1000 csr
they are realy dirty brought it to a shop to clean told them to keep the carb the same no jetting or anything like that i do not want to attempt doing myself too many small parts
Thanks rob
Thanks rob
- csrjoe
12 Jun 2010 18:16 #375331
by csrjoe
Replied by csrjoe on topic 81 KZ1000 csr
I have the 650 83 model with pods. We adjusted the carbs to be as rich as possible. It pulls good but does have what i would call a flat spot on it. He mechanic suggested to get rid of this would require a header pipe-Mac 350.00. So to ansewer your question I think the bike will need its carbs adjusted for more fuel or the bike wont pull as much as it should. I need brakes so the header will have to wait. Good Luck.
